Question about Brother MFC-5840CN All-In-One InkJet Printer
Wont print black...all other colors print. Tried to purge system, cleaned head... Dont know what else to do.
    Genius:
  • 1,325 Answers
Have you tried looking in the manual ?
have you contacted BROTHER printer ?
http://www.brother-usa.com/modeldocuments/consumer/users%20manual/um_mfc_5440cn_5840cn_en_108.pdf
Posted on Oct 16, 2010
Printer not printing black
First of all the print head is clogged just because you have tried to print repeatedly while some of the cartridges are empty. This results ink burn in the nozzle and clog. My recipe: Heat some drinking water in the kettle (70-80 C). Put the head in it and shake gently several times until ink is completely clean (10 minutes). Change the water do the same again. Change the water again (70-80 C) this time put a spoon full of apple vinegar (becomes a natural acidic solution very dilute) shake again, clean with cotton stick. I did it and started to love my mp800 again as much as I just bought it, all colours come back and started to print superior photos again......
Nov 17, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Gday heatman, how do i fix blocked inkjet in brother mfc 260c, I dont even know how to open the appropriate area yet. I have tried many purges but cant get black to work
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 25, 2011 | Office Equipment & Supplies
I need help please, I have a Brother MFC-685CW and it does not print black. I have tried the test page, as well as many other pages (online and off) and the black doesn't print. All the cartridges are new...
sounds like the little "micron"sized hole in the PRINT HEAD is plugged. if it has a purge or clean cycle like the 465c that might work. usaully soaking in denatured alcohol is the way. i dont think the printhead is accessible to humans or mere mortals like us.
usally the instructions recommend dont turn off printer
Oct 09, 2010 | Brother MFC-685cw InkJet Printer
Suddenly stopped printing all colors. Will only
Hi, it could be few things wich you having problem with.
First, how old are the ink tanks, it could be clodged.
Second the print head nozzles are clodged at that places.
Third, the purge unit does not work OK.
First remove all inks out and remove print head. Then on wet cloth, wet it with distiled water, few times press the bottom of print head ( nozzles ), then the 4 circles must change from colour to white. That means that nozzles are cleaned.
Dry head by pressing it on dry cloth.
Put it in, also the inks, and run few times the deep head cleaning. Every time take a look at print pattern.
If the head is to badlly clodged, test pattern would be just a little bit more better.
But now you know if the problem is in head or something else ( purge unit or inks ). The new head isnt so cheap regarding the printer so then the best solution would be to buy new printer.
If you do not want to buy laser colour printer, atleast buy one on wich ink tanks has printhead on. Its slightly costly, but you have one worry less - the print head is changed every time you change the ink.
Hope that helped
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Wont print black ink all outher colors ok cleand
If you did put in a new printhead, it means you need a new purge, or cleaning assembly. If it doesn't clean and prime the printhead properly, it won't print.
Dec 04, 2009 | Canon PIXMA MP510 All-In-One InkJet...
MFC-240C printer head repair
mY MFC-240C PRINTER IS NOT PRINTING WITH A MESSAGE " UNABLE TO PRINT SEE TROUBLESHOOTING
Nov 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
NO COLOR PRINT
Probably a bad purge assembly, one side cleans black and the other cleans color. Sometimes the hoses come off underneath, and sometimes the pump just fails.
Aug 03, 2009 | Canon PIXMA MX310 All-In-One Printer
I have an 8-year old Canon i9100, and have just installed my third brand new Print Head. It worked fine for one month, then the black started fading and then just stopped printing. All the other colors...
It is probably a bad purge assembly, when it doesn't clean or prime the printhead properly you have the problems you are describing. There are 2 sections in the purge assembly, one cleans color and the other cleans the black. Sounds like the black pump is worn out. The part runs around $30.00
Jun 29, 2009 | Canon i9100 InkJet Photo Printer
Wont print black but colors are fine,
Clean heads, clean heads, clean heads, etc. Then do the test print to see if the heads are open. I had similar problem with an Epson, had to clean the heads often, finally got to where the heads wouldn't clean so threw it away and bought another one (HP this time, the heads are included in the ink carts, haven't had to clean the heads at all.)
Oct 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Won't Print Any Ink
well? how old is your printer?. does your printer head is new?
reason why doesnt have printout:
1. the unit doesnt recognize the printer head:
solution: turn off the unit and turn it on again.
2. Defective logic board.
solution: replace logic board.
3. Defective printer head
solution: replace printer head
4. Clog printer head
solution: wash the printer head with water..make sure to dry
before you install it to the printer.
5. Defective purge unit.
solution: replace purge unit.maybe it wont suck ink because of the loose or broken springs under caping of the purge unit..
6. inktank.
solution: check the lips of inktank maybe it much shallow so it
wont touch the nozzle of printer head..
you need to cut the edge of the lips of inktank so it will touch
the nozzle of the printer head.
Dec 08, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
