Question about Vacuums
I got as vacuum sealer at a yard sale - I don't know the brand/make/model to find instructions for it.It is electric - has a cord to plug in - white - 2 lights on front - 'seal; ;vacuum' under unit is a model # - BS-828
    New Friend:
I have the same machine, foodsaver BS828, and no instruction manual.i need to know how to use it properly...anyone have or know how to find a manual?
Posted on Apr 20, 2017
3 Suggested Answers
SOURCE: How do I work a Salton vacuum bag sealer (Model
This style of vacuum sealer has to use a special bag with a " dimpled " surface to let the air escape through the pinch jaws of the vacuum sealer.
The folowing web site has bags and rolls that can be cut ro make any size of bag you require. You can buy on line direct from the manufacturer as well as purchase more industrial vacuum packers
Posted on May 09, 2010
SOURCE: lumina vacuum food sealer will not seal
Rang the info. number. I did not do this before because it was after hours.
The solution was simple, apply pressure with finger to lid and press start button. Evidently the plastic lid distorts when closed and does not make electrical connection. Works OK now.
Posted on Jul 20, 2009
I have a Kenmore Upright Model # 11630412001 with a broken power cord
Normally, you would leave the current power connections attached and then line up or label the new cord lines with the old.
There should be a common ground, easy enough to dsitinguish.
A hot, normally black.
A return, normally white.
These may be swapped it the existing wire colors are.
Red = new black
Black = new white
Green or Blue = Green or bare.
I'm a bit surprised t read your post as the cord should have come with connection instructions if the replacement cord is different in color scheme from the old.
The best thing is to always go online and find the wiring layout for you model.
If you have any doubt, pleast post the wire colors you do see now coming to the connection terminal and post the colors coming out of your new power cord.
Jul 05, 2008 | Kenmore 35912 / 35913 Progressive Upright...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    I don't have the instructions and I am looking for an online instructions manual on how to install this fan.
    * I don't have the instructions
    * Problem with the Vacuums
    * I don't have the instructions and I am looking for an online instructions manual on how to install this fan
    I guess you pressed SEND before you could say what it is, the brand name, and the model.
    Can you give it another try?
    It would be very nice to know if anyone can help.
    Jun 27, 2011 | Vacuums
    My husband got a 18"
    1. There is probably a hook type affair on the back of the trimmer that you are supposed to route the extension through to keep the plug from falling out.
    2. I would never do what I am going to tell you for safety reasons. It is possible to get a piece of cord, a tie wrap or a hose clamp, adjust it to fit over the trigger and around the handle so that when you pull the trigger, you slip this tight fitting device over it and it keeps it held in tightly enough so you don't have to keep your hand on it. Be advised that this is dangerous in that if you drop the trimmer or hit the electric cord, the trimmer will continue to run uncontrollably until you can get to the power, slip the device off of the trigger or the trimmer cuts the electric cord.
    It can be done, but as you can see, it can be very dangerous. These things can amputate fingers.
    Jun 22, 2011 | Vacuums
    How do I replace the electric cord for my Simplicity Shadow Vacuum cleaner model S13L? It's a canister cleaner.
    Since the problem was with the plug on the electric cord, I replaced the plug, I cut the old plug, peel off the plastic cover on the cord, they were two wires, black & white, I purchased a new plug in a Home center, attach the wires to the new plug and it works just beautiful now, it was a two prong plug, which made it easier to fix.
    Feb 16, 2010 | Simplicity Vacuums
    I purchased a toastess vacum bag sealer at Canadain Tire two months ago. I only had it about a month when the sealing wire broke. I returned it to the store and they replaced. One month later the same...
    Generic problem for all Vacuums
    I purchased a toastess vacuum
    posted by carmelwhiffe on May 07, 2008
    I purchased a toastess vacuum bag sealer at Canadian Tire two months ago. I only had it about a month when the sealing wire broke. I returned it to the store and they replaced. One month later the same thing happened again, but because it is more than 30 days I can not return it to the store this time. I have misplaced my bill of sales. Where do I go from here.
    Carmel Whiffen
    Marystown NL
    AOE 2M0
    I’m sorry that I cannot help you with this, this particular site is for vacuum cleaners only and you may want to check with the manufacturer of the vacuum bag sealer to try to help you on this matter, or check with Canadian Tire to see if they have a phone # to the factory or manufacturer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    Don – The Vac Man
    Go Ahead. Use Us.
    May 07, 2008 | Vacuums
    Vacuums Logo
    423 people viewed this question
    Top Vacuums Experts
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
