Question about Refrigerators
The ice maker is producing hollow cubes and excess water is pooling and freezing on the bottom of the ice bin. A tech who once worked on the unit informed me that the front most cube cel had the temp sensor incorporated into it and that if the front cell didn't fill with water, the ice in ajoining cells would discharge cubes prematurely, thus producing hollow cubes. He adjusted the icemaker so that the front of the unit was slightly lower than the rear, allowing the front cell to fill. When we, again, encountered the problem, I tried to get the front of the unit down as low as I could, but there'es not much "fudge room" and the problem persists. Also water from the hollow cubes seems to be collecting on the cube ejection apperatus which tends to jam the whole machine. Suggestions?
  • 1 more comment
  • lrcracklin Oct 19, 2010
    Thank you Woodchuck, your response makes sense to me, as, system wide (water dispensor, etc.) the water pressure is down by a considerable degree. The water filter has been changed recently, so I don't believe it to be the source of our problem; however, I may very well pull the refrigerator out from the wall to confirm that there aren't any kinks in the copper supply line. If I find the water flow to be sufficient from the back , then I'll do as you advise and check the interior water flow. Since we had our first service call regarding the ice maker, I've been under the assumption (per the service tech) that hollow cubes resulted from water not reaching the foremost mold where, at least according to the tech, the sensor that indicates that the cubes are sufficiently solid is located ( are you familiar with said sensor and it's location, or was I getting a technical runaround?). Therefore, all of my efforts to date have been focussed on trying to get the tray unit to tilt down in the front, thus facilitating a good water flow to the front. I plan to get on it first thing tomorrow and will let you know how thing work out. The time delay that we're encountering is due to the fact that I did not receive an e-mail response to my query and had to contact Customer Support to figure out how things work at FixYa. I'm pleased to have, at least, solved that problem and am looking forward to getting busy on it tomorrow. Thanks again, Lance Marcussen
  • lrcracklin Oct 22, 2010
    Dear Woodchuck,
    Following your suggestion, I replaced the copper water feed tube with a more flexible plastic tube. I had noticed that the copper had a kink in it where it emerged through the hole from under the house. so replacing it with plastic left me feeling as though the problem was fixed; sadly enough, however that was not the case. The unit is still producing hollow cubes for the most part (approx. 90% hollow). You had also suggested that I may have to adjust the water flow from behind the control panel, unfortunately, there doesn't seem to be an adjustment screw or knob that indicates or - water flow. I have noted that the water dispenser has a VERY low flow as well. I have no idea how the ice maker water supply and water dispenser water supply interface --- I suspect that there in a proportioning valve of sorts, but one thing to be mindful of is the fact that we have very hard water with a lot of iron in it. I have a dual canister 5 micron whole house filtration unit, but can't help but wonder, as you noted, if I might have a sediment problem. At this point, I'm at a bit of a loss. The refrig. water filter has been changed recently, so I've pretty much ruled that out as a problem, but I'm thinking of removing/bypassing the filter, disconnecting the water supply and applying compressed air to the water inlet with the hope of blowing any possible accumulation of sediment out. Any thoughts on this approach? Also, is the valve, that you alluded to in your recent note, located at the main water hook-up at the bottom of the refrigerator or up top behind a panel in the freezer compartment? I appreciate your staying with me on this Woodchuck, I've had three back surgeries, so I can only get on the job when my back allows, thus my slow responses to your suggestions. My physical limitations notwithstanding, I repair most all of my vehicles and appliances and if I'm not familiar with a particular unit, am not the least bit shy about asking a few questions and digging in. Thanks for your patience and your input. When we get this cleared up, it will certainly be worth more than $6 to me. Waiting to hear from you, Lance
  • lrcracklin Oct 25, 2010
    Dear Woodchuck, have you received my responses and results from the suggestions that you have proffered? As I mentioned in my last note, I am experiencing low water flow in both the water dispenser and( apparently) the ice maker. I have replaced the copper water input line with a flexible tube to reduce the possibility of having the line kink and it is working as expected. I have a two canister whole house filtration system (5 microns) which is necessitated by hard water which contains iron and have changed all filter media, including the canister inside the refrigerator. You had mentioned a water valve that may be partially plugged with sediment, is this valve located at the bottom of the freezer where the water supply comes in or is it located up in the freezer compartment? At this point, I am getting approx. 30% solid cubes, the remainder continue to be hollow. Looking forward to any other suggestions and a bit more specificity about the location of the valve that you mentioned. Regards, Lance
  • 4,066 Answers
Hollow cubes are caused by not having enough water in the mold.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube and causing the water to drip into the ice bin so . you don't have enough water in the old. You can take the water line off the valve and watch to see if it drips.
If you're not getting enough water in the mold
look for an adjustment behind the plastic endcover with a +/- on it.+ is more water.
Posted on Oct 16, 2010
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Our Ice maker is not producing ice. I've tried using a hair dryer to melt possible frozen water. It worked once, but now that ice maker is back to not producing ice.
The heating element is not working to heat the base and free the ice from the tray. At this point it's probably better to just replace the ice maker. They are about 60-70$
May 19, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hello, My subzero (bottom fridge) is producing ice..but only flaky...incomplete ice cubes (hollow in the middle) we've removed everything and allowed two days to rethaw..but still making the...
First thing you must check is that the temp. setting on the freezer is not less then 4. any colder and the feed line may be freezing up and not allowing the proper amount of water to the ice maker. may also need to have the water line checked at the automatic water control valve to be sure there are no restrictions of water flow. Hope this helps you.
Dec 20, 2010 | Sub-Zero 650 / O Bottom Freezer...
Ice is dumped before totally frozen.
Sounds like a water valve problem. The hollow ice cubes are the giveaway. This means not enough water. only things it can be is the ice maker is not turning on the water valve long enough or the water valve is restricted or the water valve has been leaking and has frozen the fill tube. and is only leting out a small amount of water in this case as well you will still need a new water valve.
start with water valve and if that does not solve the problem you will need to replace the ice maker.
Jan 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My GE Profile refrig ice maker makes hollow ice cubes. Why would this happen?
Not enough water is being pumped into the icemaker. The water pressure in the water line coming into the refrigerator may be too low, perhaps due to a blockage somewhere.
Move the refrigerator enough to get behind it. Turn off the water at the small valve which connects the water line from the house plumbing to the tube going into the refrigerator. Get a bucket. Remove the refrigerator water line from the on-off valve (there should be a compresson nut holding it on). Point the incoming water line into the bucket and open the valve. Do you have a good flow of water? If so, either there is a blockage in the tubing within the refrigerator or the water valve at the bottom of the back of the refrigerator is malfunctioning.
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker makes hollow ice cubs or cubes with
Whats happening is the ice isnt freezing all the way. Try cleaning your condensor's under the frig.In Hotter weather when condensor's get filled with dust it causes the frig to cycle to ofeten. In turn your cubes aren't freezing all the way.
Jun 26, 2009 | Whirlpool Refrigerators
Ice bucket/bin frozen in place
mine was overfilling because the ice was getting stuck on the way out. So some stayed in the tray and when the water would refil, it would overfil and go over the stuk cubes. leaving it to overflow to the bottom and freeze like yours.
Sep 09, 2008 | U-Line Icemaker
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
