Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
I have a whirlpool gold refrigerator model GD5SHAXkQ00 I recently had an electrical repair (resitor i think). now cools just fine but the ice maker wont work. Things I've tried.: - Used jumper wire on the unit to make sure it turns/cycles (harvest). And it spins just fine - No water is filling the unit, so I looked at the rubber line (the part I can see) and I dont see any ice. I cant seem to pull it out either. - Sensor lights. never seem to light up. Except they do turn red for a second when you plug in the refer. Other than that, no blinks. Just dark even when you push the switches etc. so motor works, no water in ice maker. But I do get water in the water dispenser. Suggestions?
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Posted on Jul 08, 2007
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
SOURCE: my whirlpool gold refridgerator - side-by-side - gd5shaxkq00 - is defrosting
I already posted this, but here it is...
The outage/start relay needed replacing. I tried it, and it worked. (The kit came with insturctions.) Total cost: $64 (Would have been cheaper if I would have been willing to wait a couple of days - +/-$45.00.)
Posted on Apr 16, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore ice maker filled with ice, but not dumping. light blinking next to ice maker switch
unfortunately, the heater is molded into the unit.
without testing every part of the icemaker there is now way to be certain which of the following has failed...
USING THIS DIAGRAM -
#11 is the heater assembly
#17 is the thermostat that controls the heater.
An entire unit replacement is not necessary.
Hope this helps.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 27, 2009
Have installed a new ice maker, it still will not work.
Soulds like the your model has a electronic eye that monitors the ice level has failed. Page 6 in the Click Here=> GD5SHAXKQ00 Parts List Location number 38 is the 2198585 Ice Level Control Board
Whirlpool Ice Maker Infrared Electronic Eye Technical Information I am here should you have questions, Thanks Sea Breeze
Apr 15, 2013 | Whirlpool GD5SHAX Side by Side...
1 week old Whirlpool Gold refrigerator. model FI7FVCXWYO ice make
Call for service as the "wet ice" indicates freezer is warm.
May 20, 2010 | Whirlpool Refrigerators
The lights that show you the numbers for the refrigerator cool are not light up
replace the control board its very common in these models especially if you recently blew out some refrige lamps,but freezer side is fine the board is $80.25 from appliance parts pros
Oct 29, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Apr 04, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not working -
If the inlet in the freezer is frozen then the water valve is leaking. Replace the water valve.
Feb 13, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker
this isnt uncomon whith sertan water conditions . try installing a water fiter ahead of the fridge ' also you can get a food grade silicone and after using your hair drier spray the ice maker ice serface and alow the product time to dry before restarting machine . food grade arisol is flamable so do not dry it with hare drier , it drys fast enough . you can get it a apliance or refrigeration parts wholesaler.
Jul 07, 2008 | Whirlpool GS6NBEXR Side by Side...
WHIRLPOOL REFRIGERATOR
my refrigerator gold is running but not cooling I have the model number and serial numbers if that is helpful please help
Apr 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
136 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
