Question about Panasonic NN-P295SF Microwave Oven
I replaced both of the oven top/night lights when one of them burned out. Now the lights will not turn off. All other functions work...even the push button switch. What's up with that?
  • Panasonic Master
  • 9,047 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Posted on Nov 23, 2011
Microwave Cooktop / Night Light not working
I would check the door switches with a digital meter, set to ohms, disconnect one wire from switch and test for open and short by pressing door switch, if you hit one that tests the same when pressing and releasing, switch should be replaced.
Mar 06, 2012 | GE Microwave Ovens
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Unit was arcing. Checked owners manual and cleaned sensor panel as directed. Stopped arcing. Worked ok for a week. Went to use last night and control panel would light and seemed ok but oven would not turn...
It is quite possible the magnetron has burned out, when it arcs it puts a tremendous strain and causes it to overheat very quickly. On top of that you found a burned mark behind the pad which is not good, so there are least two problems that must be addressed perhaps more. In any case it may be cheaper to replace the microwave oven at this point.
Mar 31, 2011 | Microwave Ovens
Replacing surface light
That's on page 33 of the owner's manual. If you've misplaced yours, it's archived online here.
Cooktop Light/
Night Light
bulb with a 40-watt
incandescent bulb
1 To replace the bulb(s),
first disconnect the power
breaker panel or pull the
plug.
2 Remove the screw from
light cover and lower
the cover.
3 Be sure the bulb(s) to be
replaced are cool before
the adhesive seal, remove
the bulb by gently turning.
4 Replace the screw.
to the oven.
Oven Light
bulb with a 40-watt
incandescent bulb
1 To replace the oven light,
plug.
2 Remove the top grille by
taking out the 2 screws
that hold it in place.
3 Next, remove the screw
located above the door
near the center of the
oven that secures the
light housing.
to the oven.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do i change the bulbs on a jvm1870sk03 microwave
That's covered on pages 35 & 36 of the owner's manual here.
your GE supplier.
or pull the plug. *
to open.
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
* If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see here.
Apr 25, 2010 | GE JVM1870 Microwave Oven
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Jun 26, 2009 | GE Microwave Ovens
Microwave PLMVZ169 GCB night light push button does not work. Replace the light bulb. Push button still does not work. The work light does when I push the night light it stays on. Just wondering how to...
Q - While trying to change the light bulb on the oven, the bulb broke. When it did, it threw the circuit breaker and the whole oven went out. After resetting the breaker, everything on the oven works except there is no power to either light socket. Any ideas or suggestions on what to replace?
A - You tried to change the light bulbs with the power still on.....tsk tsk!!
Hate to say this....but probably blew out part of the circuit on the smart board ( the brains behind the key panel you touch ) when the short blew. The light relay on the smart board may have been damaged but 9 out of 10 times when I check them, the board itself is damaged.
check out this problem.
please do rate the solution.thank you for using fixya.keep updated.thanks,
May 03, 2009 | Microwave Ovens
Cooktop Light / Night light
It is the control panel. You can actually just replace the circuit board on the control panel and it should fix this.
Nov 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Jan 14, 2007 | Whirlpool MH7135XE Microwave Oven
Panasonic NN-P295SF Microwave Oven Logo
94 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
