Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
My sony kp51ws510 rear projection tv wont power up it does nothing. can you help
    Brigadier General:
  • 8,909 Answers
It sounds like it required a new lamp a while ago and now just sits there.
I suggest a new lamp and reset the timer will probably fix your problem.
Posted on Oct 16, 2010
How to adjust the focus on my sony kp51ws510
you may need to get into the service mode for adjustments if not there is a focus botton on your TV that should do it.
Dec 31, 2011 | Sony KP-51WS510 51" Rear Projection...
Kp51ws510 power problem
Gould, heres your fix, replace both IC`s marked "MCZ3001D" on the top of the chips, they are both located on the "D" board, if your not a tech but you know how to do solder work you can buy the IC`s here 1-800-575-9833,very common fault for your set
Nov 30, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP51WS510 seven years old - have double image.
Ur tv have a problems known as a convergence problems,it is dead.The tv convergence board must be repair by replacing 2 STK convergence ICS and some or all of it resistors too.To fixed tv 3D or misalignments R,G,B colors lines tv picture.Are u willing to put in another like $300-350 for tv shops to fixed?That what it will cost for parts and labors by a professional tv tech. to do the job wright.
Jun 12, 2011 | Sony KP-57WS500 57" Rear Projection...
Black and white
The bulb is not the problem.Unplug,replug the tv about an hour.Reset the colors setting back to factory setting.The tv work,should be back to normal.Not than ur Signal tuner board have problems must replaced.
Jan 23, 2010 | Sony KP-51WS510 51" Rear Projection...
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a sony projection tv model #KP51WS510 and I was told the convergance amplifier was going out and I was needing info about where it is located so I can change it out. Thanks
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 24, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony TV Projection Screen Needed
Since TV is bit older model so your option is to check HERE for replacement screen, might they help for that.
Aug 12, 2009 | RCA P52937 52" Rear Projection Television
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
111 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
