Question about Lexmark X1270 All-In-One InkJet Printer
Printer i have a x1270 all in one printer it was working fine and i have only used it about 5 times i have checked the ink thats ok, my printer and the scanner just stop working can u please help me thanks.
  • Anonymous Jun 19, 2008
    My lexmark x1270 was working fine until the ink ran out and i replaced it with refill inks, it is now not printing anything on the page
  • sweetpeadoc Jul 04, 2008
    i try that and it didn't work thanks.
  • 48 Answers
U can try this...
Remove the power supply and replug it....
While powering on...press and hold the paper feed button....and see what happens....If it prints a test page then....uninstall and reinstall ur lexmark software
Posted on Jun 18, 2008
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Lexmark X1270 All In One Printer not printing.
If the printer has not been used for a while the catridges my have dried ink on them. Sometimes you can get them to work if you touch an alcohol wipe to the cartridge where the ink comes out. note: only touch the wipe to the cartridge for a second or two each time. I would try this for about 3 or 4 times to see if the ink will come out. Put the cartridge back in after each try to see if it works. The other option is to replace the cartridges.
Mar 09, 2010 | Lexmark X1270 All-In-One InkJet Printer
Printer: Lexmark X1270
try to check physical connection to computer and printer,
then try this steps
moz-screenshot-2.jpg1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this article can helps you to make your computer faster..
Sep 03, 2009 | Lexmark X1270 All-In-One InkJet Printer
Scanner problem
If you have internet access you need to get on lexmark site and look for Lexmark Imaging Studio,from downloading this all your problems can be sorted,pretty self explanitory and user friendly,if you are using your printer to print off photographs it is unfortunate that your colour cartridge will suffer!!
May 03, 2009 | Lexmark X1270 All-In-One InkJet Printer
My printer says E 5
Try reseating the ink cartridges. The error references to either reseating or refilling the ink cartridges.
Since you have mentioned that it worked before with only black cartridge, try reseating both and check.
Apr 02, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Hi. i have the lexmark x1270 and need to change the ink. how on earth do i go about this? i cant find where it goes?!
the x1270 has 2 seperate lids....one for access to the scanner the other for access to ink cartridges....its also hinged so should stay open while you are changing cartridges
Nov 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
X1270 scanner problem
Its the motor. If its not yet a year old call lexmark to have it replaced under waranty
Jul 01, 2008 | Lexmark X1270 All-In-One InkJet Printer
My Lexmarkx1270 will not print any black text etc
Is it a new cartridge? If the cartridge has been sitting a while it can get clogged. Try using a moist paper towel and gently wiping the cartridge where the ink comes out.
You could also try running the Lexmark Solutions Center program and use the clean nozzles option to force it to squirt out some black ink.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
