Toshiba 32LV67U took an unprotected lighting strike. I'm not a stranger to electronics. The fuse on power board is good. Two LED indicator lights light on adjacent board, so I guess power. But built in DVD nor picture sound function.
    Brigadier General:
  • 8,909 Answers
Unfortunately, with a power surge like that, untold problems from a simple power supply fault, to a processor failure could have hapenned. I cannot say how far or how near the damege is from the power supply.
Sorry and good luck, you may need it.
Posted on Oct 16, 2010
  • gary968 Oct 16, 2010
    is that it? Isn't there a way to trouble shoot some basic things? It seems no transformers are humming nor getting warm but the fuse is good. So, does that help you formulate a direction?
Model 32lv67u. Why does it have sound but no picture?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 14, 2015 | Toshiba Televison & Video
HAD A LIIGHTNING STRIKE DO THEY HAVE A FUSE THAT WORKS AS A GFDI INTERNALLY ON THE TV?
there may be a fuse ( you will have to get to the [power board to check)but normally in the event of a lighting strike that fuse is useless as the power surge jumps the fuse holder and fries the board and screen
I suggest that you take it to an appliance shop for a proper diagnosis and next time put a quality power surge board in the system before the tv and any other electronic equipment
Jul 21, 2015 | Televison & Video
Dead set toshiba mod. no. 52xv540u no bad caps,no clicking,no led lights on front
Hi, First check that you have good power coming in from plug.
If that is good check out power board (capacitors Bad) replace if oozing out or bulging out. If you are good with soldering then do so.
Replace with same capacitors or better ones.
Jan 13, 2014 | Toshiba 32AV502R LCD TV
No picture or sound
how about the power light indicator does it have or does it blinks?. ok did you tried to unplugged it for a while to reset the power supply. now if no any light indicator at the front panel, at this time you are going to remove the back cover then look if the protector fuse is blown. but before you replace it you must need a component checking in the PSU which the cause of blown like shorted bridge type diode or transistor.
Sep 23, 2012 | Toshiba 19" L4200U LED-LCD Widescreen TV,
Toshiba lcd 32c100u1 wont trun on
Hello
The power supply regulator board does not work in your TV. Just open it, and see whether any fuse has blown out. If there is any of it found, replace it with same type both in size and rating. Its ratins will be marked on it. If the replaced fuse also blow out as soon as you switch ON the set, never insert any more as it may damage more components with other boards. There is no repair to these type power baords. Replace it as card basis. You can buy it either from local electronic spare part market or from the authorised service center for Toshiba at your town. The picture of the bard is attached here for your recognization.
Oct 03, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
My theaterview tz61v61 has no sound or video i checked the fuses on the on board circuit and, with the ones i could see, seem to be fine i have little knowledge of tv ciruits and tv troubleshooting. ...
U get all solid LED lights indication front of bazel panel of the tv?U got power LED light flashes or no LED light at all?Check for DM power supply board,for dying leakage bulges up capacitors on it tops or puffing up on it tops.Replaced dying capacitors."LAMP"LED light indication on stay on or flashes.The projection lamp is dead,require changing,also hear alot of clickings too.Mean the the board call the Ballast board is also dead,require changing too.This Ballast board help to ignite the projection lamp.
Aug 05, 2010 | Toshiba TZ61V61 61" Rear Projection...
I have a toshiba tz50v51 projection tv. the red power light is on
It could either be due to the convergence Circuits ( If the Power Indicator Blinks) or the power deflection board if it doesnt blink. I have a source for parts if you would like the link.
Jun 20, 2009 | Toshiba TZ50V51 50" Rear Projection...
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
AKAI LCT26Z4AD wont power up.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 10, 2017 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
