Question about Maytag MER6772 Gemini Electric Kitchen Range
My maytag gemini is flashing H3 133 after we scooted it away from the wall to paint behind it. What does this error code mean? We cannot find the owners manual.
  • 360 Answers
SOURCE: Error message and alarm
These are the fault codes for your unit
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Hope this helps, Please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: Need an owners manual for a maytag gemini model
http://www.servicematters.com/maytag_library/docs/16010161.pdf
This manual covers your model.
Posted on Oct 31, 2009
localwonder
  • 6784 Answers
SOURCE: range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Posted on Nov 08, 2009
pride applia
  • 232 Answers
SOURCE: The Maytag Gemini is didplaying an f9-3 code, what
somthing wrong with upper door lock, bent, door misaligned, problem with lock itself
Posted on Dec 25, 2009
EllaWatson25
  • 725 Answers
SOURCE: Getting Error Code f9-5 and f9-6 on MER6770
This is a bad electronic clock assembly and it is very simple to repair. You can save a lot of money by making this repair yourself, too!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and we will get the correct part, as well part removal/installation instructions to you .
We look forward to working with you. Thanks, Ella
Posted on Jan 18, 2010
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I was baking at 350degrees. My oven turned itself off and the error code F9-3 is flashing. please assist if abe.
The F9-3 error code means that either of the two oven self clean latches is stuck so ya need to check and see in both ovens if their is something from obstructing the lacth
if you also get a F9-4 that would mean its just the lower oven
a F9-5 would be just the upper oven
but for the F9-3 it could be either oven
Aug 28, 2011 | Maytag MER6772 Gemini Electric Kitchen...
A maytag Gemini everything is working but it is flashing an F9-5 code and sometimes it throws a F9-6 any ideas on what to do????
Hi twiztedminds,
The F9:-5 / F9:-6 error code description is Latch Unlock Lower. Check for obstruction in door lock mechanism.
Hope it helps.
(Positive feedback will be greatly appreciated.)
Aug 09, 2011 | Maytag MER6772 Gemini Electric Kitchen...
My washer, model # mer6549baw is flashing error code f1-8, what does this mean?
F1:-8 Keypad Shorted
Check to see if steam or other moisture is getting into clock assembly. Replace keypad if necessary.
Jul 28, 2011 | Maytag MER6549 Gemini Electric Kitchen...
Range displays error code f9-5
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini model MER6770AAB - F1-2 error
Check the sensor for correct ohm reading. If it is good, replace the control. It should read 1143 at 100 degrees
Sep 18, 2009 | Maytag MER6772 Gemini Electric Kitchen...
How do i get fault codes for maytag gemini?
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, there is an "Error Code" link listed under the Special Features section. The Maytag Gemini series fault codes are listed there. You can print the list for FREE. I hope this helps you.
Sep 11, 2009 | Maytag MER6772 Gemini Electric Kitchen...
F 1-4 Error Code
f1 is usually bad oven control board. Look for a tech sheet on the back of the oven. This will tell what all of the codes mean and what to check for.
Sep 24, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Gemini electric range from maytag
Just unplug it and plug it back in. It will reset it.
Sep 20, 2007 | Maytag MER6872BAS Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
396 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
