Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
The wireless functionality of my Brother MFC-9320CW multifunction printer does not work with any consistency. Almost every time I try to scan a document it tells me to "check connection." Reinstalling the drivers and software has gotten the machine back online a couple of times. Inevitably, the machine gets knocked offline after a day or two and I'm told to "check connection" again. Resetting the connection on the machine itself does not seem to help. Very frustrating! I'm using Mac OS X 5.8
SOURCE: printer online then offline
Had the same problem with my mother's MFC and after 4 hours of troubleshooting I fixed it.
My mother's printer was networked through the router. Here was the solution.
1. Go to printers and faxes.
2. Right click and go to properties.
3. Go to ports (for some reason its shows Brother PC-Fax v2)
4. Add new port.
5. Enter the IP address (check the printer menu to find the IP Address ie. 192.168.002.002. To be safe enter 002 instead of 2.)
6. Restart the computer.
Wait a minute or 2 after restart and the printer should now be online.
Hope this helps you guys.
Posted on Mar 04, 2008
  • 3 Answers
My first solotution was to reinstall the printer as a new printer. But that is uncessary. The fix is as easy as changing the IP address the in Port.
The problem is the the IP address for your wirelss is not static. and when it changes, the printer does not recognize the new IP address. When this occurs. go the the printer folder ( in the control panel) and click on 'add new priter'. Then select 'add a network wirless printer . NO NEED TO INSTALL THE PRINTER...you just want to see the IP address.
Note the IP address.
GO to the printer, click on the right mouse and select 'properties'
Click on Port
You will see the current port already highlighted.
Click on ' configure port' and change the IP address under "printer name or IP address.
Click OK.
Problem solved
Good luck.
DeniseA
Posted on Mar 21, 2009
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Posted on Apr 16, 2009
SOURCE: My Brother MFC 465N keeps turning offline. I can
mfc 465 brother unable to print
Posted on May 20, 2009
the kowalski
  • 86 Answers
SOURCE: I can not print
You could try to use static ip to remove possible problems with dns retrieving:
  • Set the machine to static ip (Menu -> Network -> WLAN -> Boot Method -> Static).
  • Check the ip number on the machine (Menu -> Network -> WLAN -> IP address)
  • On your PC, go to Control Panel -> Printers
  • Right-click printer, choose Properties
  • Choose Ports and click "Add Port"
  • Double-click on Standard TCP/IP, follow the guide and type in your IP number earlier retrieved.
  • Save settings, press OK and the problem could be solved (if it was due to dns problems).
Also, if it works, you can change the network settings for scanner driver to go to ip address too instead of dns, even if it isn't a problem right now, it could later be.
Posted on Jun 02, 2009
Brother MFC-9320CW is printing blurred images
Click menu once and OK 3 times and reply the status of the test print
Oct 15, 2013 | Lexmark X7170 All-In-One InkJet Printer
Mfc 7840w wireless printer through bell router
How do I connect a Brother MFC 7840W printer to a Bell Network. Every time I try to connect, I get a connection NG message on the printer. Any help would be greatly appreciated
Nov 14, 2012 | Brother MFC-8870dw Wireless Multifunction...
Scan problem
What is it scaner or paper problem?
If it is a paper problem take out all of the paper and return few pages in the tray. Try and print out something.
But I still thing that you will have trouble.
If the things I tell you don\'t wotk you may have to change a spear part like drum unit or a toner cartridge.
Sometimes if the drum unit is at it\'s life end you may experiance this problem.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
Hi, my printer Brother MFC-9320CW enters in sleep mode every 30minutes. Any cloues how to clear the timing?
try fixing the SLEEP menu.
Follow the steps I found:
Enter Menu and navigate to General Setup. To enter press OK. Use up or down arrow buttons to go to Ecology and again press OK. Enter Sleep Time menu and enter 0 if you don't want your brother to enter sleep mode. Press OK and exit printers menu.
May 06, 2012 | Brother MFC9320CW All-In-One Printer
How do I scan something?
The brother MFC 7400c is a sheet fed scanner, so you should be able to put the paper in the paper slot, and use the scan functions. Granted its connected to a computer via usb, and you run from the computer some kind of scanning software. But for ease and reference, I've included a link to the manual.
http://www.retrevo.com/support/Brother-MFC-7400C-Multifunction-Printers-manual/id/260dj198/t/2/
Hopefully that helps!
Mar 02, 2011 | Brother MFC 7400C InkJet Printer
Networking
It isn't a network printer since it only has a USB interface (no LAN port)
http://www.brother-usa.com/VirData/Content/MFC/ModelBrochures/Brochure_MFC240C.pdf
but you may purchase a print server if you want to share the printing function on your network (only the printing function can be shared). But some multifunction printers do not work with print servers due to driver issues. There are some users on the net who were able to make this work with an IOGEAR multifunction print server.
There is one Brother multifunction network printer that you may want to check:
http://www.amazon.com/Brother-MFC-7840W-Multifunction-Wireless-Interfaces/dp/B0016ZQ566/ref=dp_cp_ob_e_title_1
Dec 11, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
1,031 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
