Just connected to cable modem from dsl
Have linksys 2.4 ghz router connected via dsl un plugged hooked to cable broadband and no internet so reconnected dsl and still nothing
I'm using linksys BEFSR41 but i cannot connect to internet when hooke it to Avaya P133G2 switch hub but when i use my old switch hub i have no problem with my internet connection.can you help me solve my problem using my avaya switch hub.
Posted on Aug 24, 2009
    Problem Solver:
  • 25 Answers
Two things are you hooked up from the dsl to the router via Ethernet or usb is so check the settings in the router, it should be auto, so it could choose but lets not assume anything.may sure dhcp client or server is enabled on the router, if not it would not pick up the ip adddress from dsl.
Is the mac address of your computer hardcoded to your dsl, if it is then you would have to clone your pc mac to the router for it to work.
If this is not the case, try a different router if it works the router is faulty. if that does not work plug the dsl directly to the pc and go to start, run type ipconfig /all if you recieve an ip address and you can see a dns address from your isp and you can go to the internet, then the problem is your router, if not the problem is with you isp dsl, please contact them. was this helpful let me know.
Posted on Jun 03, 2008
No interent connection
Your Linksys wireless router needs to be connected to a DSL or cable modem which needs to configured with the settings that your Internet Service Provider gave you.
To test your Internet connection connect a LAN cable fron your conputer to the DSL/cable modem. If you cannot connect to the Internet using this methos, you need to contact your ISP and the can check the connection to your DSL/cable modem.
Apr 12, 2012 | Linksys Computers & Internet
Not able to connect with internet using my router
Had this work before?
If yes, and you're using Cable modem then just Power cycle the Linksys router by unplugging / plugging the power cord.
If not, then you have to configure it with the correct settings for Cable and DSL ISP connection.
Check you physical connections; Modem (cable or dsl) - to Linksys (WAN or Internet port) - then plug (wired) your PC to check internet connection.
Good Luck!
Angel
Jul 09, 2010 | Linksys Wireless-G Broadband Router
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Trying to install Linksys wrt54gx2 srx200 on my vista computer
who is your broadband provider? Is this cable or DSL connection? Setting up the router is done via http://192.168.1.1. Leave username blank, password is admin. If you have Cable ISP, then make sure you have "Automatic Configuration-DHCP" selected and MAC address Clone is enabled on Setup > MAC address Clone (click Clone, and Apply). If it's a DSL connection and your broadband provider gave you a username and password, select "PPPoE" for Internet Connecton Type, and enter in your DSL username and password. Next verify if your modem is communicating with the router by going to the Status page and by verifying that you have an Internet IP address. If none, wait for a few minutes and power cycle your modem and router.
Dec 11, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Hooking up rounter to cox cable
hello!
-- what is the operating system of your computer?
-- is the router working fine before or is it a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 27, 2008 | Linksys Wireless-G WRT54G Router
Installation
hello!
-- who is your internet service provider
-- is this working fine before or is this a brand new router
Step 6: Power on the computer on and if your ISP is dsl configure the router settings by setting your isp username and password
May 07, 2008 | Linksys Wireless-G Broadband Router
Help
hello!
-- who is ypur internet service provider?
you may try ff and see if this may help you solve your problem
Step 2: Unplug the router’s power cable.
Step 6: Power on the computer on and test the Internet connection.
if this didnot work try upgrading the firmware of your router
Apr 28, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
670 people viewed this question
David Payne
David Payne
