Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
I have a BOOIL BS750 Key and Digital lock combo and currently my code is in a container from overseas but I do have the keys and I need to reset the code. The user manual is also in the same container and I need to get some documents out of the safe.
5 Suggested Answers
SOURCE: change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
Posted on Nov 28, 2009
barterjoe
  • 344 Answers
SOURCE: I HAVE A GORDON DIGITAL ELECTRIC SAFE THAT WILL
This is a bummer. The batteries go out on these and the key is the only way in then. You can drill out the key lock and manually pull back the rods but it would cost more to re-lock it than buy a new one.
A jiggler key might save the safe (no pun intended)
see a video here and check out related.
my last thought is if you wanted to pull off the face of the safe and find the two leads that run to the servo you could jump the wires with a 9V battery and it might pull the afe open.
I hope one of these ideas can help you.
please reply if I can help more
Joe
Posted on Feb 19, 2011
  • 4 Answers
SOURCE: I have a Electronic Hardline Digital Safe. I have...
inside the safe door near the hinges there is a red button. Push it and the "proceed" light on the top right of the keypad will come on. enter your new code and "A". That's all.
Posted on Jul 12, 2010
joanne_tomli
SOURCE: i have a digital home
i have digital home safe 701-5359 and left keys inside and batterys have gone
Posted on Jul 22, 2011
How do I set up a Master Lock Key Safe with a new code
Open the box, with the existing combo, push the reset lever to the left and down, dial in your new combo, push the reset lever up and right to set.
Oct 04, 2014 | Master LOCK 5401D Combination Key Safe...
We are a new business and have these key boxes but do not know the code. how can we reset?
see if the current combination is 0-0-0 as sent from the factory
once you find the combo use a pin or other to depress a button where you can choose another combo
or try here
http://www.ask.com/question/supra-lock-boxes
Oct 15, 2013 | General Electric Supra Max, Industrial Max...
I need to reset the combo from the factory set 0000 code. Can you tell me how to do that?
first open the lock then at the back push up that wight thing to the r spot then put the combo you want than kiss a sexy feet and ***
Aug 26, 2010 | Master Lock 5400d: Portable Select Access...
The wrong number was input and now we can't get into the safe, we don't have a key for it, and the batteries seem to be flat. What can we do? The safe is an electronic digital safe GX B0709
You don't know the combination code, and you don't have a key? Or you know the right combo code, but the batteries are dead? If you have the right code, and the batteries are near-dead, try the jiggle suggestion...put the safe on you lap, put in the correct combo, and jiggle the safe while turning the latch. Might work.
Feb 17, 2010 | Safe International Digital Electronic Safe...
There was a problem closing the door on the lock box. The tennant did something and finally the lock closed. I think there was a reset of the combo. Since they left we cannot open the lock box. Now we have...
I've got a similar lock here in the UK.See photo No.3 I do know that the combo can be changed but only when the box is open. The original combo is then negated and only the new one can be used. Some models have an override key
If not then from the inside the house unscrew the box. The code is contained in the outer section with the push buttons. Look at the back and there should be visible the locking pins under a back plate with pin numbers - usually the tops of the pins are coloured red=a number of the combo code
If no colours can be seen, remove the plate, with care as there are small springs under it, then push and hold the C cancel button and ease out the pins noting that the pins are grooved, differently for lock and non-lock Lay them out on each side of the lock and look for a number of them with the same grooves equal to the No. of combo digits & the pins will be the lock pins. Replace in the order of your new combo No. and reassemble [these pins are handed - a left will fit a right by rotating through 180 degrees]
Hint - watch the springs they can fly out and are vital
Hint - note new combo in cell phone
Hint - red paint tops of pins for next time
If this is a key storage box, I have this too. email me plz rod-davies&hotmail.com
Jan 11, 2010 | Master Lock 5400d: Portable Select Access...
''The protector'' gun safe I need a user manual
If it is "The Protector" from Costco, open the door and put your hand back by the top of the rear of the door in the seam. There you should feel a little button, push and hold til it beeps then enter your 4 digit code, hit "A" and release. Lock the wheel with door open and make sure your new code works.
Apr 01, 2009 | House Brand Sport & Outdoor - Others
Resetting the combination
The reset works when the current correct combination is set on the front. If you forgot the combination, you can go to the www.masterlock.com and download a PDF to request a combination from the factory to open it. It requires a notarized form & takes 6+ weeks. In the end, it is probably easier to buy a new one. When resetting the combo, I accidently scrambled it as I flipped it over. And did not know the combo. The reset button would not work. I did some guess work around the setting and got it to release again.
Jan 08, 2008 | Master Lock 5400d: Portable Select Access...
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
522 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
