Question about kawasaki Garden
I have a Kawasaki kt18 (31111ua) bushwacker. Was not firing properly and and started to take the rear section of got the recoil off then and being silly i tried to force the casing the magnets in it and the rest of electrical was damage as well.
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: My Model 358-795200 Weedeater/bushwacker won't
Hi istabler1...
Sounds like yiou have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
NOTE: Before you dissemble the carburetor:
Make sure you mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you dissemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 26, 2011
Testimonial: "Thanks, you confirmed some of the things I have done, but have given even more, thanks so much for all of you help! Truly appreciate the fast response"
Replace pull cord 2 hp eska outboard
saddleethod as any pull start engine
remove the recoil section from the engine and replace the cord
it not sure how to do it , take the recoil section to a service shop
May 17, 2017 | HP Boating
How to fix my Tanaka chainsaw rope to recoil back?
replace teh recoil section as there is a problem with the spring or the pulley section holding the cord.
Apr 26, 2015 | Tanaka TCS33EB/14 32 cc Gas Powered 14-in...
How to adjust valves on a kawasaki mule 4010 trans
You must have a mark on the main crank shaft, and take the spark plug out, slowly and manually turn the crank shaft, put screw driver inside the spark plug hole and screw driver will raise and when stop and then go low turn back that your tdc
Aug 21, 2014 | Kawasaki Mule 4010 Trans Full Cab...
HOW DO YOU SHARPPEN BLADES ON ELECTRIC HEDGE TRIMMER BUSHWACKER?
proper method is to use what is referred to as a "lapping table" professional sharpening shops have these , look in your yellow pages for scissor sharpening , but if your a skilled hand and have some time then a simple fine file will work as well , keep same angles on cutting edges ,approx. 30 degree angle
Jun 17, 2014 | Craftsman Bushwacker Bush/hedge Trimmer...
I just changed spark plugs on my 650,now i cant pull over the recoil to start it. never did this before!!!DONT UNDERSTAND,JUST CHANGED PLUGS!!!PLEASE HELP
wrong plugs maybe put your old ones back in it ya have them if not take out new plugs and pull recoil if it turns over then get another set of plugs
Nov 02, 2013 | kawasaki 2005 Brute Force 650 4x4
I just bought a 1987 Kawasaki Ninja GPZ 750R that needs carb tune/rebuild attention. Get it home and first day starting it up it immediately backfired. Now the starter just buzzes, sounds like it is...
I will try to make a suggestion, but Fixya has a motorcycle section and you are listed in the cars and trucks section.
Starters have an end part called a bendix. When the starter turns, the bendix expands on the starter shaft. This puts the gear against the flywheel. In your case, it seems the gear extended and failed to recoil back out of the way.
This is why there is no clearance now. Two different approaches to creating clearance are to remove the starter endcap and grab the stator and twist it to unscrew the extended bendix to a compact size. Or remove the sparkplugs, jack the rear wheel off the ground and engage the transmission, then rotate the rear wheel in a manner to imitate reverse.
By reversing the rotation of the wheel, it should reverse the rotation of the engine flywheel and spin the broken bendix into place. By removing the sparkplugs you eliminate an accidental ignition and you all but eliminate compression.
An extra pair of hands to wiggle the starter would help as the rear wheel is turned.
Carburetion problems can be caused by bloated gaskets. Any carb built before Ethenol was distributed will swell and block fuel ports. In Automotive, these newer gaskets for Ethenol are blue, I can not say about Motorcycle applications.
It should be possible to remove the starter either way.
Aug 07, 2013 | kawasaki Motorcycles
FC420V Kawasaki back fires thru carb on cold start,runs and starts fine after difficult startts
It sounds like your valves may need to be adjusted...
if they are too lose or worn they won't seat properly and when the engine fires it blows back through the intake valve.
pull the cover and see if the rockers are loose... it only takes one to give you a headache.
Mar 29, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
117 people viewed this question
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
