Question about Yorx PT1900 Television
Yorx TV yes i have a 5" color tv Yorx Model PT1901 and i would like for someone to call me at 480-585-5872 in regard if i can use this tv with the batteries in it when the digial comes in 2009.... the manual says this equipment is comply witht the class B digital device... because i want to use it when the power goes out here in Az. thank you
  • Anonymous Nov 14, 2008
    I have the same problem. Exactly but I am in St. Louis. You can email me at pcbrawner@gmail.com
Hi Cheryl,
We have the same problem with a different model Yorx TV. The sad part is that this TV has a great antenna that gets clear reception but its built in and the converter the government offers doesn't work. If you get a solution, drop us a line as it might work for us. We will do the same. I am actively pursuing a solution using a "smart tv antenna" made by RCA. I will let you know how it turns out. pcbrawner@gmail.com
Posted on Nov 14, 2008
HI. I Have a PT1900 TV and I am looking a external antenna jack so I can hook up to cable or to coverter. Thanks Chuck 330-207-4096
Posted on Sep 26, 2009
After about 30-60 minutes TV starts to hum and picture gets distorted, could this be the color wheel...???
Sounds like a sync problem due to color wheel speed. clean and lubricate color wheel motor with tiny amount of Z-Max lubricant (liquid Buckey balls, available at Wal-Mart), on each bearing. make sure wheel is free-wheeling and turns easily. Should cure problem. If the color wheel is in good shape, there is a power supply problem, which may be due to dried out electrolytic capacitors or a regulator that's failing. Troubleshooting or controller board replacement may be needed. Regards.
Dec 07, 2015 | Mitsubishi WD-73840 73" 3D Home Cinema...
Color
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
Jul 24, 2010 | Sharp 65DR650 65" Rear Projection...
Codes
Hi, Take a look at this link, I hope it helps you, if not let me know.
http://www.remotecodelist.com/remotes/
Regards - Anthony
Feb 08, 2010 | Emerson Televison & Video
Do i need to change my lamp? or is something else?
is your tv a dlp?
maybe it can be you tv lamp..
need to know first.
Jan 25, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Vedio Card for Panasonic CTV TX-34G400W
Try Ebay.com or craigslist and look for one I am sure someone might have that part, good luck
Apr 22, 2009 | Televison & Video
Three separate images about 4-5 inch apart on my TV
Symptoms shows TV has problem of faliure of convergence out ICs. (2 ICs in TV) and need to be replaced.Let me know do you want to repair it at your own? ...
... if yes, it is necessary to have experience of TV repair and basic electronics knowledge.
Nov 23, 2008 | Sony KP-51WS500 51" Rear Projection...
Yorx portable tv
i need help with the Yorx portable tv 5". i think the model no. is PT 1901 ... can you tell me if this will still work when the digital comes in. it runs on batties as well... I NEED HELP WITH THIS TO KNOW HOW I CAN STILL HAVE IT WORK...
THANK YOU
CHERYL YOU CAN CONTAC ME AT 480-585-5872
Dec 04, 2007 | Yorx Televison & Video
TV stuck on AUX
unplug the tv then plug it back in the wall
Aug 30, 2007 | Orion1934 19" TV
Televison & Video Logo
252 people viewed this question
Top Yorx Televison & Video Experts
Are you a Yorx Televison and Video Expert? Answer questions, earn points and help others
