Question about Maytag Neptune MDE5500AY Electric Dryer
Gas dryer MDG 7057BWW spin but no heat - Maytag Neptune MDE5500AY Electric Dryer
    President:
  • 3,074 Answers
This may help:
http://www.applianceaid.com/gas_dryer.html
Posted on Oct 16, 2010
Burning smell but not odd sounds
make sure vent is cleared MDG is a gas dryer so sometimes when theyre heating it may smell different than youre used to. blower impeller wheel has a "D" shaped hole & can round out causing it to hang up the motor which could cause a burning smell but usually will make a lot of noise B4 that will happen.
Jun 29, 2012 | Maytag Neptune MDG5500AW Gas Dryer
My neptune mdg 5500 dryer starts and runs but will not get hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune gas dryer model nbr MDG 4000 BWW. Dryer runs well but doesnt heat up. ...
A very common problem in a non-heating gas dryer is what is called the gas coils, especially if it will light briefly and then go out and not relight. You should also check the igniter and make sure there are not cracks or burned places, also thermal fuse and thermostat could cause a no-heat.
Dec 01, 2009 | Dryers
Dryer does not heat up.
Hello there:
normally on these units if the dryer was working ok and then suyddenly stopped heating your heating element or the ignitor (excitor ) has failed and is need of replacement
so i would start by having these things checked first by contacting a local repair man to do a evaluation on the unit and if kyou still have a valid warranty i would use it ok
I hope that this is very helpful for you
Best regards Richard
Nov 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maaytag gas dryer will not go above 90 degrees F.
either your thermal cutout in the exhaust line,the heat cycling switch are bad
Nov 09, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune dryer MDG 7500Aw won't heat
Replace the glow bar ignitor.
Aug 04, 2009 | Maytag Dryers
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
69 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
