Question about Whirlpool Duet GHW9150P Front Load Washer
Replacing water pump in front loader whirlpool washer
I need instuctions like you gave mr to clean the garbage out that gets stuck.we followed steps 1-12 and there was cgange and stuff in there but it still won't drain i think we have to replace the pump.we would like to do it our selves.we really can't aford a repair man right now. could you help?
    Genius:
  • 1,028 Answers
Before changing pump rermove all hoses and ck for coins a quarter can turn on side and block hose also ck down in pump throat 1 screw at front of pump and slide pump back to remove..pump will run $125-$160
Posted on Jun 04, 2008
How to replace drain pump
The following link explains step-by-step how to replace the drain pump on a Whirlpool Duet series front loader:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
If you have any questions, please post back and let me know. I hope this helps you.
Apr 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tip
F21 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Apr 05, 2010 | Kenmore Elite 45986 Front Load Washer
Tip
on Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Something is stuck in our LG front loader washing machine so the water wont empty in the spin cycle
There should be two screws under the front lower panel. Remove the two screws and remove the lower panel. You should be able to access the pump from here.
Inscrew the cover on the front of the pump and clean.
Dec 31, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Our front loader washer is stuck in "drain mode". It sounds like it is trying to drain and some water comes out. The door and all controls are locked. Already tried the usual fix.
water left in machine tub? if so the pressure sw is probably telling the board keep draining. in this case open front cover and drain pump through cleanout access and clean tray-possible clog.
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet front loader ghw9100lw error code F02
if your hearing clackling try and clean the pump and the hose leading into the pump for a coin ,,small ,,(dime),,,hair clip,,also its a must that you use he detergent,,or you sude up,,if you do use he your using to much,,now bleach the unit out on a normal cycle hot wash cold rinse with about a pint of bleach...and no you can purchase part of a pump..it comes as you see it in unit..onthejob
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader duet sport washer door will not open
without complete f code hard to pin cause but suspect pump not pumping out remove bottom cover reach up to lock area pull small tab down to unlock door remove as much water as possible remove pump clean out by turning counterclockwise clean pump and connecting hoses reassemble and ck
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Doesn't drain
Is the weird noise a grinding noise? You could have something lodged in your drain pump impeller. If it has gone on for some time, you may need a new drain pump at this point. The pump should have a trap that collects all kinds of things that make it into your wash tub and get washed down the drain line. If the washer is still full of water, do yourself a favor get a wet/dry shop vac and remove as much water as you can FIRST. You can try pulling water from the drain hose or directly from the wash tub. This will save you from having to clean up a huge mess later. Now, unplug the washer and remove the lower kick panel directly below the door. The first thing you need to do is check the drain line coming from the bottom of the wash tub to the pump. Squeeze the line and feel for anything that may have gotten stuck in the line. Socks, underwear and wash cloths are notorious for getting past the wash tub and getting stuck. Now, check for a screw off type of clean out trap on the pump. If you have one, this will be an easy step in checking the line and pump from obstructions. Be prepared with some old towels to collect any residual water. If there is no drain trap, you will have to remove one end of the drain line closest to the pump and check the pump and line that way. Good luck and let me know if this helps you.
Jul 03, 2007 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
