Question about Craftsman 20 gal Horizontal Compressor
Pratically new craftsman dry pump air compressor will not reach shut off pressure, reaches 100 and will not get higher it just continues to run.
    Brigadier General:
  • 4,088 Answers
The compressor valves may require replacement, the drive belt is loose, or there is a leak somewhere on the tank--usually the safety release valve. Hope some of this helps!
Posted on Oct 16, 2010
  • Producer Nov 12, 2010
    may have a broke leaf valve inside the head - take it apart and inspect the valve plate. If the intake valve is broken you'll see it. Replacement costs about $17 from Mel-Co parts on eBay - or $27-$40 elsewhere.
    I had the same problem with my older model (1993) Sears air compressor
I have a craftsman air compressor model # 921.16472S. When it got to cut off pressure the bleed valve started blowing. I changed the pressure switch and bleed valve then lowered the cut off pressure. When...
Either the pressure switch is not shutting off when reaching the desired pressure or the pop off is either the wrong one or it is bad. Some blow off at lower pressures for single stage air compressors while others blow off higher for 2 stage air compressors.
Feb 11, 2014 | Craftsman Air Tools & Compressors
I just purchased a used pro source 10 gal. It don't shut off is that normal? I see it says 2.0 continuous. So that mean as long as its on it runs.
The rating of 2.0cfm continuous means that your a/c can produce that much air at certain pressure as long as it runs. It should shut off when it reaches cut-off set pressure. If it does not reach say 125-145 psi and shut off then mostl likely air is leaking from joints or piston/cylinder worn out. Spray soapy water on joints and look at top part of cylinder from under side of pump and look for scratches. If scratched, air is leaking past cyl/piston. Good luck.
Nov 08, 2012 | Air Tools & Compressors
Compressors
The pressure regulator on an air compressor is designed to let the pump motor run until the pressure in the tanks reaches their safe level. While you are using the air the pressure drops in the tanks until it reaches the level where the pressure switch turns the motor on again and refills the tanks to their rated level. The pressure where these two things happen is usually with in ten psi above or below the rated levels because few regulators are so precise and are affected by temperature that they turn and off exactly at the rated pressures. If a pressure regulator is damaged or broken it is possible for the tank to either reach unsafe high levels or not turn on when the pressure drops to where it should restart the motor. If you are in doubt, have the regulator checked or replaced as overpressured tanks are very dangerous.
Jun 24, 2012 | Craftsman 150 PSI Air Compressor
Compressor runs to 175psi but trips pressure relief when pressure drops tries to restart motor but motor wont turn blows breaker. changed whole pressure switch have same problem.
The problem is lilkely the check valve between the compressor and the tank -- it is alowing pressure to build from tank to compressor preventing the compressor from turning over. Clean, maybe replace, check valve...
Charlie
Jan 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
My regulator broke and I just replaced it. Now the compressor doesn't act like it will automatically shut off when it reaches pressure (130 psi max). Last night it pressured up to right at 130 psi and...
Hi, my name is John. Welcome to FixYa. Look on the pressure switch and see what the max. is. I have some notes here I will have to locate them and I will post them here if you still having problems, but it sounds like you need to replace the pressure switch. Thanks for choosing FixYa...John
Nov 20, 2010 | Craftsman 33 gal Air Compressor 6 hp...
Put new switch on compressor and now wont shut off.
the regulator is failing to do its job. make sure you have it set properly. if you did, you will likely need a new one. also remember to drain the compressor every month to prevent rust from moisture build up in the tank. good luck.
Jun 03, 2010 | Campbell Hausfeld Air Compressor 32 HP...
MY COMPRESSOR JUST KEEPS RUNNING AND WONT REACH MAXIMUM PRESSURE AND SHUT OFF. I CAN SHOOT NAILS BUT IT WONT SHUT OFF DOWN.
The compressor itself sound like it is bad. You might see what it cost to repair it. It might be cheaper to get another one...keep in mind if you do a lot of work with it that a 2 stage compressor will cool better and you won't have this type of problem again.
Oct 19, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 20 gal Horizontal Compressor Logo
88 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
