Question about Car Audio & Video
I need the coler code for the speakers on a 1995 chevy chyenne 1500 pickup
    Genius:
  • 1,478 Answers
The voltage in speaker wire is too small to cause harm. Plug the two wires in. If the speakers work the wires are correct. If the speaker doesn't work try them the other way.
Take care.
Posted on Oct 16, 2010
How to change the low beam light bulb on a 1995 chevy pickup truck?
the light bulb will be located at the back of the light houseing some low and high beams r in the same bulb
Sep 06, 2014 | 1995 Chevy 1500 Pickup Truck Grill with...
Need to change ignition switch i have removed the steering wheel. need futher instructions on removel and replacement for ignition on a 1993 chevy chyenne 1500 4.3 manual transmission truck.
Inside the column with the steering wheel off,You should see a phillips screw at the 1:00 position . remove screw . this should allow lockset to be removed.
Apr 05, 2010 | 1993 Chevrolet K1500
How many quarts of transmission fluid does it take in a Chevy 1500 series 350 vortex pickup?
just droppin the pan? Nearly a perfect 4 quarts. Completely empty, convertoer and all? Around 10 - 11 quarts
Jan 18, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
REMOVAL OF DOOR PANEL on a 1995 Chevy C1500 Pickup
Take a clean rag and work it behind the window crank to remove clip. Then remove the 2 screws in the armrest. I used a plastic shoehorn and started at the bottom right hand corner of panel and popped the plastic pins from the retainers. Pull the panel away from door and yu'll see pin holding door handle assembly . Undo the pin and replace assembly. Installation is the reverseo
Mar 13, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
I need to replace My steering Column and I dont know If I can interchange it with any years common to the 1990 Chevy Chyenne Pickup truck With a manul transmission
yes you can as long as it is 88-98 years the main electical plug may be diferent just cut and splice the wires together blue to blue red to red so on if thare is two of one coler twist them together it will work fine.
Mar 11, 2009 | 1990 Chevrolet Crew Cab
1995 chevy 1500 pickup 4x4 4L60E trans
the computer is different on the 4l80e put the wiring should be the same. the case has the same bolt pattern. The bolt pattern stayed the from on the pickups from atleast 2001 down. You can use an LS series style motor's transmission if you wanted. You will just have one less bolt in the transmission case to the block.
Feb 20, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
Car Audio & Video Logo
13 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
