Question about EliteGroup NFORCE4-A754 Motherboard
I've been searching for couple of hours and still haven't found why the heck I can't install the ethernet card of this mobo. Device manager won't even show it in the list of devices... not even hidden ones. Help please!
    Genius:
  • 1,325 Answers
What CPU are you using AMD or Intel
go to the elitegroup site .. see if this helps you with network driver requirement
http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=9&keyword=NFORCE4-A754
pleaas esne dpositive feedback , if this helps
Posted on Oct 16, 2010
ASUS P8Z77-VLK Intel Z77 Motherboard - P8z77vlk usb dirver won't install correctly
After you have run the installer, restart again. It's hardware software, mobo driver.
Aug 23, 2012 | ASUS P8Z77-VLK Intel Z77 Motherboard -...
I'm trying to locate the drivers for nvidia Nforce 10/100 lan drivers for an hp pavilion dv9000
Hello
There is a driver disc with this lan card. If you haven't got it when you buy it, it will be very difficult to install it from the net. Anyway, try to download it from the following links. Wich a CD, it will take about 30 to 40 minutes to install the sofftware fully. The disc will install both LAN card driver and Nvedia driver together.
www.nvidia.com/object/nforce_udp_winxp64_6.25.html - United States
www.pcpitstop.com/drivers/manufacturer/nvidia.html
http://www.dataentryjobs.us/67948.html
www.liutilities.com/device-driver/nvidia-nforce-10-100-mbps-ethernet/
Feb 03, 2012 | Computers & Internet
After spending a couple hours searching I haven't found anyone with a similar problem, so I hope someone here can help. I have an old RM 2807 that I have been restoring. I've managed to get...
This is a common problem with the OEM control boards. I replace the RM2807 control boards with the new "Dinosaur P-711 control boards which are quality made and will hold up in the long run. Here is a link to the control board you need.
Sep 17, 2011 | Dometic RM2852 Refrigerator
I want update Ethernet Controller but I dont know how
  1. Click "Start" to open the "Start" menu.
    Right-click on "Computer" or "My Computer," depending on your version of Windows.
    Click "Properties."
    Click "Device Manager." This will be located on either the upper-left side or on a tab at the top of the "Properties" window, depending on your version of Windows.
    Double-click on "Network Adapters" in the "Device Manager" window. This will display your Ethernet card.
    Right-click on your Ethernet card and click "Update Driver Software..."
    Select the option to search automatically for updated driver software. This option will search the Internet for any new drivers available for your Ethernet card. If you presently have the latest drivers then you will be prompted that the latest drivers are already installed on your system and the window will close. If new drivers are available they will be automatically installed.
Mar 04, 2011 | Computers & Internet
Dell Latitude C600, Ethernet adaptor NOT FOUND
Visit the Dell Web Site.. Use the Service tag on On under side of laptop.. and All Drivers are on the Dell Support Web Site!
Oct 09, 2009 | Dell Latitude C600 Notebook
How to instlall PCI device driver for integrated ethernet
Check the name of the card or model, download the driver to Internet just search for that? you'll needing to reinstall manually the driver of the PCI adapter to your computer.
Mar 12, 2009 | HP D330 PC Desktop
ABIT is7-vs no ethernet
Have a closer look ... that appears to be in IS7-V2 board
http://www.abit.com.tw/page/uk/motherboard/motherboard_detail.php?pMODEL_NAME=IS7-V2&fMTYPE=Socket 478&pPRODINFO=Driver
If the link doesn't work right you may have to copy and paste the entire link into your browswer
Download the Realtek Lan driver you should be good to go
Robert
Please take a moment to rate this solution thank
Feb 03, 2009 | ASUS P4B533-VM Motherboard
No internet connection
Have to reinstall ethernet driver. Need to use a usb wireless to get online, then choose search online for driver, or right click the ethernet adapter in device manager and choose device ID and search for driver on another computer and then install it on yours.
Dec 20, 2008 | Motorola Mobility 17235 Network Adapter
Can't connect to wireless
You need a wireless card installed and a wireless router connected to your internet connection. try newegg.com
Dec 06, 2008 | IBM ThinkPad T21 Notebook
Network Card
Yes the network card is the same ethernet card. If your intel pro/100 is onboard try to re install the driver from the motherboard drvier. Check also in the manager device it the network device have a complex to the other device. Follow this, Click START then RUN type DEVMMGMT.MSC then enter check if the network adapter have a yellow question mark. If you found the network adapter right click and uninstall it.and click the ACTION and click SCAN FOR HARDWARE CHANGES. After the installation finished try to connect to the internet. If still the same even you input the correct ip in the network configuration. Buy a new LAN card it's not expensive, because usually the onboard lan is easy to damage or not working properly you can installed and configured it but you cannot connect to the internet.
Apr 15, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
EliteGroup NFORCE4-A754 Motherboard Logo
26 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
