Question about Dell PowerEdge SC430: SC430 Server 2.8GHz pentium Duo Core, 1GB DDR2(2x512MB), 80 GB HDD(7200RPM) NO... (POWEREDGESC430DELLSC430) PC Desktop
Dell Sc430 Poweredge gives out Hot Air...Nothing to do with the performance all stable .but it gets difficult to sit around it and work..
    Brigadier General:
  • 8,909 Answers
What can I suggest?
Maybe there is a problem with the processor working too hard as there are too many files to get through?
Maybe a virus is in there making the hard ware work too hard?
Have you noticed the hard drive light working more than normal? if so this could be a reason as the processor will have to work harder, causing more heat, when it is busy trying to cope with an extra problem.
Posted on Oct 16, 2010
  • ronmy2008 Sep 25, 2011
    This server was working for 7mos and it was shutdown last July 2011 and got powered in last Monday after cleaning.
Dell Poweredge SC430 Shows error Code 3.
Wow!
Haven't seen anybody use the term Microprocessor, for a long time.
How about CPU instead? Shorter, easier to type, carries a certain 'savior faire' to it; and will help teach people not to use it to mean PC. Personal Computer.
(Central Processing Unit. Microprocessor is another term used, or simply Processor for short )
I'm going to assume you are following Anti-Static Procedures.
If not the CPU's you have touched, are now key chain fobs.
(Drill a hole through them for the chain, lol!)
Have to go through the basics. It isn't an insult to your intelligence, I just need to go through a diagnostic flowchart in my mind.
CPU installed the correct way? Aligned correctly?
With the LGA 775 processor socket, the CPU can be turned, and installed wrong,
http://en.wikipedia.org/wiki/Socket_T
http://en.wikipedia.org/wiki/File:CPU_Socket_775_T.jpg
That little alignment 't1t' can get crushed.
What CPU did you install?
Do you know if it is supported?
The motherboard chipset is an Intel E7230,
http://www.intel.com/content/www/us/en/chipsets/server-chipsets/server-chipset-e7230.html
Supports;
A) Dual-Core CPU's
B)Front Side Bus support of either 800MegaHertz, or 1066MHz
(800MHz / 1066MHz FSB)
C) Hyperthreading Technology (HT)
However, depending on the CPU, you may need to perform a BIOS update.
With the old CPU going out, and now the new CPU doesn't work, I would suggest going back to the start of the diagnosis, and look into the Power Supply.
The Power Supply is the FIRST thing to look at, when diagnosing a desktop computer. Server notwithstanding.
A Power Supply with a weak voltage power rail, will emulate all sorts of software problems, and hardware problems.
Have a multimeter to use to test the 3 main voltage power rails?
(3.3 Volts DC, 5 Volts DC, and 12 Volts DC)
Or;
Have a KNOWN to be good, Compatible power supply, you can borrow for a temporary test unit?
Post back in a Comment.
Regards,
joecoolvette
Apr 14, 2013 | Dell PowerEdge SC430: SC430 Server 2.8GHz...
What could be the problem when you power on Dell Sc 430 Poweredge, you get only a blinking orange color?
these servers are single power supply when that goes you only get a blinking orange light and no beeps.
most other issues will beep code.
I would start there. you can remove and reinstall. but it is probably bad
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 23, 2011 | Dell PowerEdge SC430: SC430 Server 2.8GHz...
I can not see display while i start my dell poweredge sc430.
check your cable PC to monitor or try to added vga graphics card
Jul 22, 2011 | Dell PowerEdge SC430: SC430 Server 2.8GHz...
Does not display the operating system
when you say not displaying the OS. is it booting up?
if you need the OS,
click start on the lower left of your screen
you cn type in msinfo32 in the search bar
-- or --
you can also right click on the computer button or Mycomputer and choose properties.
Send us a feedback if it works.
Mar 04, 2011 | Dell PowerEdge SC430: SC430 Server 2.8GHz...
No power on my PowerEdge 1800 Server
dells power supplies must come from dell. I would call dell and give then the service tag number of your server and they will be able to tell you about how much a power supply is.
May 02, 2010 | Dell PowerEdge 1800 Server
Dell PowerEdge 2300 - Monitor, keyboard and mouse will not respond
It sounds like the power supply is failing.
Failing power supplies will sometimes deliver just enough power to make the fans spin but not enough for the motherboard and drives to start.
I hope this helps.
May 28, 2009 | Dell PowerEdge 2300 Server
NO Audio out put
dell2_bing.gifpoweredge servers are not needed for sound. DELL support will notsupport any sound cards or care anything about your audio issues. Youwill not find audio drivers because again, a server's purpose has nothing to do with audio.
Jan 27, 2009 | Dell PowerEdge 600SC (Refurbished)...
DELL Poweredge 2600 Bios FREEZES After Cpu check and before SCSI Drives check HELP!!!!
The BIOS check can freeze for many reasons.
Can you tell me if this is an existing system that was working fine and then had this problem, or is this a new (or new to you) system?
Can you give more information on what is actually showing on the screen?
Nov 05, 2008 | Dell PowerEdge 2600 Server
Computers & Internet Logo
60 people viewed this question
Alun Cox
