Question about HP PSC 2410 All-In-One InkJet Printer
Hi. I have never needed to use fax part of printer but now I do. I'm unsure how to set this up i.e telephone connection to printer from computer to phone socket? Can you help, I'm desperate!!! Thanks Sue
    Problem Solver:
  • 12 Answers
Hello Sue
You may find the HP Support document at this website very useful: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=303752&prodTypeId=18972&prodSeriesId=303752&objectID=c00259105
Barbara Grey
Posted on Oct 16, 2010
How I can receive fax through computer with HP1312?
Hi a barati75
A fax transmission is an analogue communication that was possible on a computer with the old technology of Dial up Modems, which accessed the internet by dialling like a landline telephone. The Broadband Modems (or Modem/Routers) in widespread use today have an 'always on' internet connection and, therefore, no dialling is involved in internet access using them.
You can send a fax by dialling out on the All-in-one printer's telephone number pad. Receiving a fax automatically requires you to have the All-in-one printer's Transmission/Reception Settings set to 'Automatic'.
This fax setup requires the printer's fax cable to plugged directly into an empty Telephone Line Socket on the ADSL filter that plugs into your Telephone Wall Socket and has inputs for your Modem (or Modem/Router) and a Telephone line. If, as is common, your ADSL Filter only has a single Telephone Line Socket and you also require a telephone to be plugged into the same socket as well as the Fax Machine component of your printer, then a Telephone Line Socket Doubler must first be plugged into the Telephone Line Socket of the ADSL Filter which then receives the Fax Line into one socket and the Telephone Line into the other. Please note that every Telephone Socket in the building sharing the same circuit/telephone number must also have an ADSL filter between it and any telephonic device (Telephone/Fax Machine/Answering Machine/Stock Control linked EPOS (Electronic Point of Sale) System/Card Payment Processing Machine, etc.), in order to enable both Computer Internet Data and Telecommunications Data to share the same line without conflict.
Your question asks whether a fax can be received "through" the computer. The above description enables your printer to send and receive faxes 'independently' of the computer while simultaneously providing the computer with printing, scanning and copying functions. For faxes to be sent and received via the computer, software is required. The simplest and most efficient of which is Efax (Electronic Fax (available from www.efax.com) and other similar software available from a variety of suppliers. This software enables the user to send any document or image stored on the computer by fax (without first having to print it) and to receive faxes, at any time, in the form of attachments to e-mails that the software opens, usually as a non-editable PDF or other similar secure Document Format. Faxing a physical document via Efax requires the user to scan the document and save it on the computer first, before sending it.
A combination of a Standalone Fax function setup using ADSL Filters and Socket Doublers + Efax gives the user optimum flexibility in sending and receiving faxes.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment/Clarification Request to this Question.
Thanks for using FixYa
Sep 15, 2011 | HP LaserJet CM1312 All-In-One Printer
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
I can't recieve fax
The MP500 is not a fax machine. If you want to send and receive faxes using the printer, you need to have a dial-up modem in your computer with a telephone line connected. The computer then needs some kind of fax application like Microsoft Fax, which does the actual sending and receiving. The printer is just used as a scanner when you send, and to print received faxes.
If you have all this connected already and you can't receive, check your incoming telephone line and fax software settings to be sure the line is answering correctly.
Mar 03, 2011 | Canon Pixma MP500 All-In-One InkJet...
Will the HP 6210 work with VOIP and Win 7?
HP Officejet 6210 All-in-One is not tested on VOIP connections when it was in manufactured. However these printers do work with VOIP connection.
If you are unable to get the printer working on VOIP connection, there are few ways to fix this.
1. Reduce the Fax speed of printer ( from Setup - Basic Fax Settings - Fax Speed ). Try to Fax
If this does not work, try the step below
2. VOIP is Digital technology and HP 6210 works on Analog Signals ( standard telephone line )
- You need a DSL Filter which converts the Digital Signals to Analog and vice versa. This filter is available at any departmental store or computer accessory shop
- Connect the DSL Filter to phone socket. Connect the printer telephone cable to Analog port of DSL Filter ( to Line 1 Extn port of printer )
Either of this should fix the solution. However there is another solution which may or may not be possible. It is to reduce the baud rate on your Cable connection ( though not recommended )
Regards,
Shawn
Jan 28, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Need manual for connecting fax to phone line and computer
Simple:
* one telephone-wire from wall-outlet to port on FAX labelled "line" or "telco";
* one telephone-wire from port labelled "phone" (or an icon of a telephone) to the port on your computer's modem labelled "tel" or "telco" (if your modem has more than just one port).
So, "incoming" telephone-calls go the FAX, to be "answered" by the FAX, while "outgoing" dial-up-Internet connections from your computer's modem "pass-through" the FAX, and to to the wall-port, and further along to the Internet Service Provider.
Jun 15, 2010 | HP DESKJET PRINTER, HP OR COMPATIBLE
Don't have a manual how do i connect this fax machine
If it is FAX only machine, just replace your telephone with your fax. Connect it to the telephone plug asif it is a telephone.
You have to change the settings to FAX only of fax/telephone.
If your All-in-One printer/fax/modem, then you need to download a driver and install the computer.
First of all look for the brand/model and down;oad a driver to install.
Hope this will help you.
Best of luck
luciana44
Oct 05, 2009 | HP Office Equipment & Supplies
How do you set up fax phone on the HP officejet 6215
hi you really have a very good choice of printers is one of the best printers from hp
inorder to set fax on ur printer you should first be sure what type of telephone line you are using
there are 2 type of line 1 dedicated -> that is directly attached for fax and has no other telephone or TAM connected if you have this line you can directly attach the phone line on the printer line 1
the other type of line is shared that means you use the same line for phone and fax in this the connection should be as :- telephone line from wall jack to the printer line 1 then from printer ext port to telephone answering machine (if any ) then from answering machine to telephone (if u have a dsl line that means u use phone and internet from the telephone line then there will be 2 lines comming out of the splitter 1 to router and other to telephone here follow the shared line connection mentioned above using the line that goes to the telephone )
now power on the printer and press the setup button (menu) now navigate to basic fax set up press ok and then go to rings to answer it should be 4 rings now go back and go to advance fax setting and then to distintive ring (DRP) select all rings and press ok now run fax test if it passes then ur fax is set up try sending fax now hope this will help you
Jul 22, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hi there. I have just taken over this office and am not sure what is connected and what is not. I am trying to send a fax through my computer and the "waiting for printer to respond:Canon MP830...
you need to give more details on how you're trying to send the fax.
keep in mind you don't actually need a printer to send the fax if you're using your computer to send the fax.. that's the reason you need to be more precise when discribing your problem.
in general you need to be familiar with how things are connected.
if your printer is a fax machine too the minimum you need is to have your printer/fax connected to a line (to the telephone wall jack) and to be powered up.
if your printer is only a printer and you're using your computer to send the fax you need to have your modem (the connector in the back of your computer that looks like a telephone line but says not telephone but 'line' connected to the phone line on the wall) connected and have software that allows you send faxes via your computer. (windows xp has that software so you need to make sure is installed (start>control panel>add remove programs>add/remove windows components>fax services should be installed) and if the software is installed you should be able to go to start>accessories>communications>fax>fax console
confirm what is your set up and give more details.
Oct 17, 2008 | Computers & Internet
Hi, I am setting up a canon mp730 for a friend. I have run into a problem with the fax phone line. I have connected the lines correctly to the copier and her answering machine but when I try to use the...
Remove the connection and once again try to re connect the lines between the copier and phone line . You might have some connection . Just give a try .
If this doesnot work . I will let you know how to proceed further .
Oct 12, 2008 | Canon Office Equipment & Supplies
Faxing
You need Option, AR-FX7 (FAX) installed, real easy to figure out, look at the side, if you see a telephone line, with line and telephone connections (not the Network connection) then you have a fax.
Next your arm237 will also need to be able to print from the nextwork.. if this is all together..
you will need a driver called, PC to Fax for the AR-M237.
which you can find at www.sharpusa.com
Then you will have to set up the computer in the printer folder to PC to Fax.
Sep 29, 2008 | Sharp AR-M237 Copier
HP PSC 2410 All-In-One InkJet Printer Logo
21 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
