Question about Maytag 30 in. CSE9000 Electric Cooktop
None of my burners will turn on - Maytag 30 in. CSE9000 Electric Cooktop
    Problem Solver:
  • 9 Answers
Is there a place where there are fuses? try replacing any burned out fuses
Posted on Oct 16, 2010
Testimonial: "That was it! You are awesome!"
Burners wont work any more
Good Morning Fern mullen, I appreciate your post!
Based off what you have described your burners are no longer working on your Frigidaire range. This could be an issue with your control panel or the switch. I would recommend performing a reset on your range and you can do that by disconnecting power from the range for at least ten minutes. If that does not help correct your issue I would suggest having a technician out to your home for a proper diagnosis and repair. Best of luck! -Matt
Feb 28, 2015 | Frigidaire FGEF306TMF 30" Freestanding...
I have a 6 burner range top. When I turn on 5 of the six all 6 spark as they should and the correct one lights. When I turn on the left front knob none of them spark and it will not light, but gas does...
The problem is the burners switch the the single burners has failed, this will cause is not to fire the module and ignite the burner. I would replace just that burner switch to correct the problem. When you call for parts, make sure you have the complete model number and possible color of that burner switch needed. They make or have available switch that are sold by color, so color may be needed for this model.
I hope this helps.
Sep 20, 2013 | Viking 37 in. VGSU161 Gas Cooktop
None of the burners igniter clicks so none of the burners will light. Could the spark module have gone bad?
That is definitely a possibility. If you can find the module you could disconnect the wire going to the switches (at the valves) and then hook up the module to 120 volts. Careful! Don't get shocked.
May 24, 2011 | Amana 30 in. ACC3660 Gas Cooktop
Burners are sparking when none of the burners are turned on and only stop when electrical source is shut off.
Water has gotten into one of the igniter switches (below the burner knob). Disconnect power, let it dry out for several hours, and things should work again just fine.
Jan 02, 2011 | Kenmore 36 in. 33212 / 33214 / 33219 Gas...
GE Monogram ZGU48N6D- None of the Ignitors "click"
We just had that problem - the igniter is electric - if none of the burners are "clicking" it could be a power problem. unplug the stove and check whether the outlet is working. In our case, the outlet the stove is plugged into has a "GFI outlet with a reset button. So we reset the outlet and that fixed the problem.
Apr 08, 2009 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Elect Ign not sparking, but get gas, other appliance working.
I don't know, I did nothing, it just started working again??????
Jan 28, 2009 | Maytag 30 in. CSG7000 Gas Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Cooktops Logo
110 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
