Question about Philips 42PFL7422D 42 in. LCD TV
My Phillips 42PFL7422D/37 power starts but then shuts down before the screen comes on; you can hear the relays click on and the little blue 'on' LED on the front comes on for about 20 seconds and then all power shuts off.
  • 132 Answers
Go to your manual to see if there is a timer setting for shutoff.
Posted on Oct 16, 2010
My phillips 42pfl7422D/37 has Solarization pl help!TV set was use with playstation game console!
Other than replacing the panel there Not an easy fix for solarizarion/ ghosting
Jul 05, 2016 | Televison & Video
Tip
42PFL7422D/37 Flat Panel LCD TV no picture no sound
I HAVE A 42 INCH PHILIPS MODEL 42PFL7422D/37 TV.
MY PROBLEM IS THAT IT HAS NO PICTURE AND NO SOUND.
THERE IS A GLOWING BACKLIGHTING.
THERE IS A BLUE LIGHT WHEN I TURN POWER ON THE TV. NO CLICKING RELAY SOUND.
MY PROBLEM WAS IN THE SLAVE INVERTER BOARD.
THE IC CHIP WAS BLOWN - SEE PICTURE. THERE IS A BURNED, DARK BROWN MARK ON ONE OF THE CONTACT LEADS ON THE CHIP.
THERE ARE $20 FIX IT KITS THAT YOU CAN BUY ON EBAY TO REPLACE THIS TINY LITTLE CHIP BUT IT'S RECOMMENDED THAT YOU SOLDER VERY CAREFULLY. I TRIED, AND DAMAGED THE BOARD SO I BOUGHT A USED ONE.
REMOVING THE IC CHIP IS PROBABLY BEST DONE WITH A HOT AIR SOLDER GUN. THEY COST ABOUT 50-200 DOLLARS.
AFTER INSTALLATION IT FIRED RIGHT UP.
IN ADDITION TO THE JUST BUYING ANOTHER INVERTER BOARD, I ALSO TESTED THE MASTER INVERTER TRANSFORMERS. ON THE POWER SUPPLY BOARD, I TESTED THE DIODES, AND RESISTORS, AND CHECKED THE FUSE.
AFTER ALL OF THE ABOVE, I UPDATED THE FIRMWARE BY GOING TO THE PHILIPS WEBSITE.
LUCKY FOR MY SITUATION IT WAS NOT THE MASTER INVERTER, MAIN , TCON, POWERSUPPLY, OR DAMAGED BONDING ON THE LCD PANEL ITSELF.
TOTAL COST $50.
GOOD LUCK!!!
on Dec 23, 2011 | Philips Televison & Video
My Phillips TV (42PFL7422D/37)light comes on to show power but the screen does not light up. It does have sound. Guy on line stated it most likely is the T-con board/LCD controller. That this is common...
Try to to put-off your lights and see if you have slight illumination on the screen, if it does, its the t-con board. If totally none, you have to change your Inverter board.
Jan 19, 2015 | Televison & Video
My phillips model #32PFL5332D/37 flat screen will not come on
You have been the victim of a power surge. It will need to be repaired in order to work.
Sep 29, 2017 | Philips Televison & Video
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
42PF5321D/37
That is correct about the SSB. Now before we go any futher is this set still under warranty? If so or if it is just a little out like a couple of months contact Philips @1-888-744-5477. PS. on the front of the set where the power button is how mant times do that led blinks.
Aug 20, 2008 | Philips 50PFP5332D 50 in. Plasma...
42PF9956/37 SHUTSDOWN...
Ok. I got my tv back on.
I pulled off the back cover and found the relay that was clicking.
I have two blue relays next to each other that click when the power is pushed.
I placed a hair dryer over the relays for about a minute.
Once heated up, it only took 4 tries to get the TV to stay on.
Jan 03, 2008 | Philips 42PF9956 42 in. HD-Ready Plasma...
42pf9956/37 philps plasma
I don't know why but this got my TV on.
I took off the back cover and found the source of the clicking.
Two blue plastic rectangular relays in the exact middle.
When I pushed the power button, I felt the top relay click, and I saw a flash from the bottom one. (they are right next to each other)
I took a hair dryer and placed it over the two relays for about 1 minute and tried the power.
It clicked only 4 times and then came on!!!!!!!!!
For some reason heat helps the relay.
If anyone is a tech and can explain this, please do.
Good luck!!!!
My tv is on and it didn't cost me anything.
I just can't turn it off now!!!
Sep 25, 2007 | Philips Magnavox 42MF521D/37 Television
Philips 42PFL7422D 42 in. LCD TV Logo
547 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
