Question about Sony Handycam DCR-PC120 E Mini DV Digital Camcorder
When i turn on the video camera, (Sony DCR-PC120 NTSC) the screen goes blue and displays a blinking C:31:22. Does anyone know what is causing this? thanks
Drawsalot
  • 38 Answers
SOURCE: error code sony dcr trv25 c:31:23
Sony says the unit needs a power reset (error 31). Unplug the camera, remove the battery and wait several minutes before re-attaching the battery and/or AC cable. Then power the camera back up. The 23 code says you need to use a InfoLithium battery-- apparently these are smart batteries that give data back to the camera. These error codes seem to be quite common however, and so a hardware issue may be the case. Some users have said that removing the battery while the camera is powered on will clear the codes. Others advocate "smacking" the camera, I would not however, recommend this. www.sony.com is a good place to look for more information.
Posted on Nov 21, 2007
ctf1800
  • 4402 Answers
SOURCE: "Reinsert the Cassette"
go here
Posted on Jun 11, 2008
SOURCE: C:31:23 error with DCR-PC101 Sony camcoder
Had the same error message on my TRV-720, and could not come up with a solution for weeks until I found this website:
http://www.protechcam.com/wwwboard/messages/127.html
Now the fix you will not believe, nor did I at first, but requires you to power off the unit completely and "Smack it" a few times fairly hard.
Now you may do this at your risk, but I swear it fixed mine and all the other people listed at the above web site.
I thought it was a joke - but it works!!
Good Luck!
Posted on Jul 28, 2008
welcomejee
  • 10594 Answers
SOURCE: Handycam says C:31:22
error 31:22 means camera mechanism has error in take-up reel section and micro processor isn't receiving reel signal so it shuts down playback/ record function immediately. look into take-up reel section of mechanism.
Posted on Sep 12, 2008
SOURCE: C:31:23 Flashing and viewfinder says "Reinsert the casette"
i know what setmaz says sounds kind of ridiculous; but i got desperate and tried it myself... i can say that as far as i go its a proven method and the camera will start working
Posted on May 14, 2009
Sony DCR-HC40 NTSC the problem seems to be erratic, but get a blue screen and will not play back in play edit mode and will not record.
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Dec 26, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Can i transfer the video to my pc from my sony handycam dcr pc120?
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
Nov 30, 2010 | Sony Handycam DCR-PC120 E Mini DV Digital...
My camera is SONY Digital 8 DCR -TR 7000 NTSC. I cleaned the head, as instructed. But now i see a blue screen . I dont know whaat else to do. Help please. It is a Digital Video recording. a...
Hello, yes I know what you mean, the blue screen is because it is a blank area of tape you are playing, or the digital camera setting have been switched on by accident, check all your menu setting are off.
Jun 10, 2010 | Sony Handycam DCR-TR7000 Digital Camcorder
Sony DCR-TRV260 NTSC
When video heads got dirty / clogged, camera gives this error.
Use good quality Video Head Cleaning tape to clean heads.
Dec 19, 2008 | Cameras
DCR-trv460 NTSC
I'LL SEE IF I CAN GIVE YOU SOME IDEAS TO CHECK. I'M NOT COMPLETELY FAMILIAR WITH YOU CAMERA, BUT MY EXPERIENCE HAS BEEN THAT A LOT OF THESE CAMERAS WITH BOTH THE LCD SCREEN AND THE VIEW FINDER, SOMETIME HAVE A SWITCH OR BUTTON TO TURN ONE OF THE DISPLAYS OFF IF DESIRED. IS THIS POSSIBLY THE CASE? ANOTHER THING IS YOU MAY HAVE AN ELECTRICAL PROBLEM THAT IS NOT SUPPLYING POWER TO THE LCD. HOPING THE CAMERA HASN'T BEEN DROPPED OR HIT HARD OR SOME ACCIDENT TO IT COULD ALSO CAUSE THE LCD TO QUIT WORKING. DID THE LCD JUST QUIT SUDDENLY? BATTERIES GOOD? DOES IT WORK WITH THE AC CORD, IF THERE IS ONE? I KNOW, LOTS OF QUESTIONS, BUT I'D LIKE TO HELP YOU FIND THE CAUSE OF YOUR PROBLEM. IF YOU LIKE REPLY WITH MORE INFO AND WE'LL WORK ON THE PROBLEM MORE! OK? I'LL BE GLAD TO HELP.
ARCLIGHT1217
Nov 01, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Display on camera is all red and black with static
call sony support there is a know problem with the cable to the lcd
Feb 26, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam DCR-PC120 E Mini DV Digital Camcorder Logo
75 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
