Question about GE Dryers
I turn my dryer on for 5 minutes & it feels like its about to catch on fire it gets so hot...ive cleaned alll the lint out even out of the backside
    Problem Solver:
  • 9 Answers
Have you vacuumed the lint or blown thru from the lint catcher thru the machine into the wall outlet and then even the wall outlet. I found a bunch of lint inside the dryer that could not get out because the vent was plugged almost all the way to the outside wall. My vent has to travel a long way to the wall.
Once I did this, it alleviated the heating up of the dryer
Posted on Oct 16, 2010
GE dryer, no heat?
Your heating element is most likely burned out . Have you made certain all of your lint vents for the dryer are not clogged ? Also , be certain to clean the lint filter every time you use the dryer. A buildup of lint in the dryer , in the hoses & on the back of the dryer inside in between the drum & the outer covering can get so hot it will catch on fire when the heat is working , and also , without a fire will burn up your heating element.
May 18, 2012 | Dryers
What can make the dryer catch fire
There are sensors usually about 4 located all along the element housing.
They are about the size of a quarter and about 5 times as thick...
Their purpose is to sit and wait until it gets hot...if its too hot, they open the circuit until it cools, then its back on again.
On occasions, they may not trip and allowing the element to go into "after-burner" mode and will catch lint or any thing else nearby on fire.
Hope this helps...
Jul 30, 2011 | Whirlpool LER4634J Electric Dryer
Takes 5 hours to dry a medium load of clothes. Clothes feel slightly warm and damp when removed.
clean out your dryer vent the hose going from your dryer to your house the vent from your laundy room to the out side of the house make sure the vent is as straight and possible and no kinks
also clean your lint screen with soap and water if you use fabric sofener sheets they have a chemical that clogs the screens the watter should flow right thu the lint screen and not puddle up at all
do this asap you are risking damaging your dryer and worse yet your house could catch fire
Nov 16, 2010 | Kenmore 700 6972 Dryer
When I turn on the dryer, the top gets VERY hot within about 2 minutes. When I look inside, you can see the heating element is red. I checked the vent and it is clear. I did notice that there was some...
if the lint is damp then the air isn't moving out the vent line,unplug the dryer, go outside and make sure the hood is clear, then go back inside and remove the vent line from the back of the dryer,if the vent line is long i use a leaf blower to blow out the line,just stick it into the vent line and blow it so all the lint will go outside,if you could have someone watch the outside and they can let you know when the line is clear,also the duct that the lint filter slides into should be cleaned out and you should vacuum out where the motor is,you have an open flame inside the dryer and the lint can and will catch fire if it's not cleaned out,i do this to my dryer once a year,the clothes dry on time,no fires and the parts in the dryer last longer from being cleaned and the dryer isn't overheating and damaging the motor and other parts from running to hot.let me know how you make out
Oct 29, 2010 | GE DVLR223 Dryers
Won't dry, but get's very hot in the back
yes, unhook the vent to the back run the dryer if it heats better then either replace the venting or clean it out... hint use a leaf blower to blow that line out....... lint blockage or cloggage in the vent will reduce dryin times and yes possibly start fire... when it is on go outside to wear it vents and see or feel if it is blowin outside... hope this helps
Jan 30, 2010 | Frigidaire Dryers
I turn my dryer on and it immediately gets hot on the top of the dryer. So hot you would get a 2nd degree burn if you touched it. Then you can start smelling a burning smell. I've checked outside to make...
If this is as you say, please contact your appliance dealer as soon as you can. You are right, don't use it. You dont' want to be seriously injured nor injury someone else and as for your place catching fire, not a remote possibility.
Sep 21, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
The dryer is getting extremely hot even to touch the outside, what could it be?
Urgh, woe be to those owners of Maytag units (I'm sooooo done buying anything with that name on it due to poor experiences, but I digress...), do you clean out your dryer from excess lint build up at least once a year? No matter if it is a gas or electric dryer, most folks do not do this & wind up paying dearly whether it be financially or with the dryer catching on fire, which can cause untold devestation! Get your vacuum cleaner out & use the slimmest attachment you have to do this. You may even take a hanger or other slim sort of poker to stir up condensed/compressed lint at the front of the dryer & then turn it around, remove the exhaust hose & do the same before using the vacuum to **** out the excess lint. You may also want to make sure the temperature regulator / thermostat thingy is in good working order, as that too can cause your dryer to use higher heat than necessary. Good luck.
Aug 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My amana dryer, model # LEA90AW will run for 5 - 10 minutes, then shuts off. It won't start for about 20 - 30 minutes.
try cleaning the lint filter it is possibly overheating
If you dont know how to do this get it serviced before it catches on fire
Jul 30, 2009 | Dryers
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Dryers Logo
49 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
