Question about Microsoft Xbox 360 Console
How to clrean a sracth disc - Microsoft Xbox 360 Console
  • 104 Answers
Either get some scratch remover sold in video game stores or take it to a local video game store
Posted on Oct 16, 2010
'05 Scion tc shocks me when exiting vehicle
Clrean the ground connection to the vechicle frame.Hook a peice of rubber strap from the rear frame long enough to contact the roadway , make sure the strap slightly drags when driving.
Dec 29, 2013 | Problem Solvers Vehicle Parts &...
The paper will not feed through when printing
clrean the rollers
using the printer maintenance , its built in under services
use the correct setting for the paper type '
check for small pieces of paper or objects caught in the paper path
tip it upside down see if anything falls out
Aug 19, 2012 | HP OfficeJet 7410 All-In-One InkJet...
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
My modern warfare 2 disc used to work then my mother moved my xbox while the disc was still in there the disk got scratched and i got those sracthes repaired but it still dosent work i can go on for like 2...
I think mom needs to by a new MW2 . what's happened is
there is some very sensitive areas on the disk that absolutely
can not have any distortions or scratches or it will get kicked
out as a unreadable disk . the laser lens CUT a deep grove
that is difficult to buff out. the CD will have to be ground down
then buffed out a 2 step operation . I have done it but it takes
the right equipment and grinding compound.
Sorry to here about that ( I love MW2 )
Rob
Sep 13, 2010 | Microsoft Xbox 360 Console
A notice came up that my Brother MFC-440CN printer was out of cyan color. Bought a new cartridge and installed. Printer continues to say that there is no cartridge is installed? Got another cartridge and...
IS it a genuine cartridge or a refilled or compatible?
My recall is that some compatible wern't for this model
It could also be that the jet that receives the ink is blocked. There is a special cartridge that can be applied that has a clreaning fluid in it. You put it in as normal and select maintenance to invoke a clean to get it fixed.
please rate my help++++Thanks for using FIXYA
May 07, 2010 | Office Equipment & Supplies
I am printing bar codes. In the bar code it is laying down more ink then it should leaving big lines that can be sracthed off. I am using a Zebra 170 XILLL PLUS.
In the software provided adjust temperature setting of print head before printing the job. Please also check for bad ribbon. Please don't hesitate to ask if any further assistance is needed. Good Luck
May 01, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
The gamecube keep sracthing up pokemon colosseum
well make sure that its not on a algal, and that you don't move it at all when its moving
Oct 04, 2009 | Nintendo GameCube Console
Evry game this is unreadable but has no sracthes
The CD drive is probably going bad, or is bad so, you should probably contact the system's manufacture's website and see if you can get a relpacement.
Jun 14, 2008 | Video Game Consoles & Games
My game
its sracth how do i clean so it will be clean?
Mar 04, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
