Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
My liftmaster garage door opener won't work via the wall putton or either of the remote contols. It does not run at all, only makes a clicking sounds two times, and the light comes on and stays on for five to ten minutes or so, then the light goes off. It was doing this the other day. I waited about fifteen minutes, and it began working working again. It worked fine for 4 days and now it is doing it again. It has not worked for three hours now, and I have tried it at least 10 times.
  • 504 Answers
UNPLUG THE UNIT WAIT 30 MINUTES.
PLUG IT BACK IN & TEST IF THE UNIT STILL JUST CLICKS I WOULD REPLACE THE CIRCUIT BOARD.
HOPE THIS HELPS
Posted on Nov 10, 2010
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
Apr 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a 3/4 horsepower liftmaster garage door opener, both the remote and the wall button won't close the garage door but both will open the garage door. however, the garage door will close if I hold...
If when closing the door it reverses to the open position and the main light flashes 10 times it is a door sensor problem. Make sure the small light on each sensor is on and not flickering ever so slightly. (check closely) Tweak them a little even though they may seem to be okay. Check for 5vdc between terminals 2 and 3 on the rear of the motor unit. If there is no voltage or if it is greater than 6vdc the logic board is bad.
Sep 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
I had to manually close my craftsman garage door and now it won't respond via the remote or the wall button. Chains move but not engaging with door.
Look for a red handle with a rope attached along the bar from the main unit to the door. Pull this handle and release until it engages the track again.
Jul 07, 2011 | Craftsman Sears Liftmaster Garage Door...
Opener has been working fine for four years. Today, when I pressed the remote to get into the garage, the door opened for a few inches, then stopped, and now the motor will not run at all, via the remote...
The problem may not be the garage door opener, To determine this, Pull the emergency release to release the door from the carriage. (The red cord that hangs from the opener) Now you can press your garage door opener to see if your motor works. If it still does not work, try unlpugging the opener from the power source for approx10 seconds. This should reset your motor.
If the motor works, the problem is with door and not the opener and you need to consult a professional who can help you with this.
Jun 23, 2011 | liftmaster Garage Door 1/2 Hp
Garage door opener makes a clicking sound when activated by the remote or wall unit and the lighton the back of the opener flashes. craftsman.
If the opener is making a clicking sound when it is running the chain is too tight. Post back with the number of flashes from the light.
Dec 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hi I have 1/3 hp liftmaster garage door opener that will not open from the remotes but will open with button on wall. I think it is a reciever problem?? any suggestions?/
reset your remotes and your main transmitter after removing and replacing the remote batteries (these use rolling codes that change each time you operate the door) the procedure for doing this is listed on the liftmaster website
Apr 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Grage door blinking yellow, click and won't open with anything.
TRY RESETTING THE UNIT BY UNPLUGGING IT FOR ABOUT 5 MIN.
IF WHEN YOU PLUG IT IN THE REMOTES STILL DON'T WORK TRY TO REPROGRAM THEM.
IF STILL HAVING TROUBLE--
COUNT THE FLASHES - GOTO LIFTMASTER.COM DOWNLOAD A FREE PDF FOR A SIMILAR UNIT (THE MODEL NUMBERS ARE DIFFERENT BUT THE CODES ARE THE SAME).
HOPE THIS HELPS
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
457 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
