Question about Skil Saws
Skil 7313 Classic Belt Sander was running and sanding. Belt snagged. Changed sanding belts, but it would not run.
cloe2594
  • 29 Answers
SOURCE: Dremel belt/disc sander
see the manual
Posted on Nov 06, 2008
  • 2692 Answers
SOURCE: Burgess BBK20
Instead of the face of the pullies being perfectly straight,a slight crown , meaning high in the center, will help the blade track to the center better. Most of the big band saws have crowned faces on the pully faces where the blade acually touches. The other option is to look for wear on the ajustment system or shaft(s) bearings.I am persuming no vibration while running.
Posted on Dec 29, 2008
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
  • 302 Answers
SOURCE: how to adjust belt on skil belt sander
There should be a tracking adjustment knob on the side of the sander behind the front roller. Run the saw and adjust this knob to center the belt. You will probably have to do this every time you change belts. Hope this helps you...
Posted on Sep 12, 2009
SOURCE: what is the belt size of a skil 593 belt sander?
2 1/2" x 16"
Posted on Sep 13, 2010
I have a pressure control skil octo Sander .i think i pressed down to hard now the pressure light stays on and it won't sand but Motor runs good
The transmission between the motor and the sanding belt has been damaged by the excessive pressure you applied. Check it carefully to see if something got bent and operation can be restored. If it is gear driven and you broke off some of the gears then .....................................
Sep 16, 2015 | Skil Tools & Hardware - Others
I have a skil sand cat 2.5 x 16" belt sander model 593 no manual how do I put on and take off sanding belt?
The people at Skil will provide the data you seek Contact them on-line via this link. https://www.skiltools.com/Parts-And-Service/Pages/Email-Us.aspx
Mar 04, 2015 | Skil Tools & Hardware - Others
Cannot tighten then belt on a skil 594 belt sander
Have you tried the next smaller sized belt? If you tried a 24", have you tried a 21"? ... or, if you tried a 21", have you tried an 18"? ... etc.
Aug 12, 2013 | Skil Tools & Hardware - Others
What causes my belt sander to leave black goo on the wood? I keep replacing the sand belt, I do not push the sander into the wood.
Maybe you are burning the wood. If the wood is hard (like oak or maple) and the grit is fine (like 100 or higher) then this can only be avoided by NEVER running it still in one place. Keep the sander moving quickly over the surface. In fact, you should start the sander BEFORE you touch it to the wood, and when you do touch the wood you should be landing it like a little airplane on the runway. As long as you keep the sander oriented with the grain you can move it forward and back as well as side to side. Just keep moving until you lift it off of the wood - this also helps keep the surface flatter. Good luck.
Jul 30, 2012 | Skil 3 in. x 18 in. Belt Sander - 7500
I have a Skil Belt Sander 405. I bought at a sale. How old is this sander? How can I get a belt for this sander?
http://cgi.ebay.com/4-x-21-3-4-sanding-belts-36-grit-qty-10-/310329120043?pt=Sanders_Sandblasters&hash=item48410e952b
this is the type of belt it uses (size rather) 4"x21 3/4" you can find them on ebay.
http://www.skiltools.com/en/ here is the official skil website. they can probably email you an owner's manual if you wish
hope this helps out. this one is vintage from what i understand
thanks,
mike w
Jul 07, 2011 | Skil Tools & Hardware - Others
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
How to adjust belt on skil belt sander
Sep 11, 2009 | Sander Tools & Hardware - Others
Saws Logo
166 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
