Question about HP Office Equipment & Supplies
The bottom half of the text is not printing (as if it's being cut off)
    Problem Solver:
  • 6 Answers
Your question does not tell me what printer you have so I will assume it a modern HP made after 2004.
HP Printers use a ink cartridge and this is connected by a tiny pipe to the print head that sprays the ink on the paper. Your problem is with the Print head and not the ink supply.
There is a remote chance that some paper felt or paper dust, or even a stray piece of tape has blocked the lower part of the print head. I assume that this is the black print head, so that is the head marked with the letters K Y (Black and Yellow) on most modern HP Printers. Try to clean this using the clean or clear functions found in the maintenance section of the Printer Software. If that does not do the job then follow the instruction to replace the print head but rather replace the print head use a clean cotton pad with a few drops of alcohol to gently clean the print head and replace it as per the instructions. If that does not do the trick then the bad news follows....
Because the lower part of the Print Head gets the most use (., and underlining all use the bottom part) its also the first part of the Print Head to fail. If you live in the U.S. or Canada the print heads are not expensive. Go out and buy just the Black (K Y) if that is 80% or more of your printing use. If you are doing a lot of color it pays to buy the two heads together in one package.
Posted on Oct 16, 2010
Why does every other line of print have the top half of the print cut off?
The print head prints two lines of text/image at one time. If there is a partial print of alternating lines, you probably have a partially clogged print head. Print a test page to see what you get, and perform head cleaning process if needed.
Dec 29, 2015 | HP Photosmart 3310 All-In-One InkJet...
Printing text at the same label in two directions
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Zebra TLP 2844-Z Thermal Label Printer
Printer cutting off words
Is this happening with every program you use to print? If it's just a single program, try changing the line spacing. It sounds as if you've got the line spacing too small for the current font and it's cutting off the bottoms in order to print the next line.
Jun 10, 2013 | Canon Pixma Mp530 Office All-In-One Inkjet...
When printing from a Zebra TLP 2844, text is getting cut off. I am printing from internet software, center aligned. If there are too many characters, the text is getting cutoff on either side (I would say...
Check the drivers you are using, try downloading drivers from Nice Label or Segull Scientific. Setup the page size to fit all the text, use a ruler to measure the lables.
Apr 27, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Only prints on bottom half of label.
Your scanner and thermal printer has got loose connection. Print head also may need cleaning by own system. try from the software.
JMC
Aug 12, 2009 | Dymo LabelWriter 330 Thermal Printer
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
Printing not proper
Adjust the printing properties from normal to best.
Mar 28, 2009 | HP DeskJet 3940 InkJet Photo Printer
Every other line prints only bottom half of text.
I have a psc 2355 printer which only prints half of text then the next lines are ok then it repeats only printing half text. I removed my ink cartridge and wiped the ink ports with a tissue heavily moisten with water. Repeated this several times and then gently dried with a tissue. The problem was fixed!!
May 08, 2008 | HP PSC 1610v All-in-One Printer
CX6600 horizontally cuts text
Change the colour of the text to print each colour The same text once in each colour- then you will know what the faulty colour is. Download this utility www.ssclg.com install it and learn to use it. Also go to www.fixyourownprinter.com and take a look At #Epson printers there
Jun 16, 2007 | Epson Stylus CX6600 All-In-One InkJet...
138 people viewed this question
Seeker5211
Seeker5211
