I have Time Warner Service set up @ home for my Home PC. I bought a Netgear N300 Wireless Router for my laptop. Do I have to plg into the Time Warner Modem to set up my Laptop? ANd what do I do?
  • 4,340 Answers
The modem wants to plug into the wan or internet port on the router, this port is usually different in color and location from other wired ports.
You will want to program the router settings, either use the wizard, or change: Wireless security wit WEP at least, and give a password, like you home or cell phone number (which you can remember when a guest comes and needs access), change system ID to something you would remember, change router access password AND LOG IT,
and check that the router broadcasts it's presence (usually set to yes), and finally change the channel to 11 and get less landline wirelss phone interference.
To do this programming, by the way, you usually need to plug into the modem with a network cable and direct your browser to it, something similar to 192.168.1.1 in the address bar, but get the manual and follow their directions.
Posted on Oct 16, 2010
    Genius:
  • 1,325 Answers
The router comes with power plug -- plug that in, but not yet
-- first you need 2 ethernet cables RG45, plug one end into router(into port marked cable or main, the other end into ( i assume you have hi speed modem) into modem
-- plug one of the other ends of the second ethernet cable into one of the 4 ports of the router and the other end into the computer RG45 port (make sure its in the correct port, if you have a modem in your computer be carefull, as these to connections are different in size, although they look alike) -- if you have one, the modem in your computer is a fax modem used to connect to a telephone jack with regular telephone cable, so dont confuse the two connections
-- now plug the router into AC outlet
-- once you have accomplished all this , make sure your equipment is turned on
are you with a telephone hi speed or cable hi speed ISP company ?
if this helped you,. plese send me a positive feedback repsonse !
Netgear N300 is slowing down my internet connection
The router limits the data speed to the wireless reception.
802.11 G speed (maximum) is 54Mbps.
Jul 17, 2013 | NetGear N300 Wireless Router
How do i turn the wireless on so i can unplug the laptop from themodem
Hi Ray,
I believe there is an ON and OFF switch on the Front Panel of your Netgear N300 Router, push on the button and see if the Wireless light will turn on.
I hope this helps.
Oct 02, 2012 | NetGear N300 Wireless Router
I have two rj45 points looped with a router and xbox 360 plugged into both but only one will work at a time?
I would figure that you would start with the modem feeding the N300, then connecting the XBOX by cable to the netgear, and then using the laptop wirelessly through the netgear...The modem should feed the Netgear so the Netgear can split the signal...
Jun 09, 2012 | NetGear N300 Wireless Router
Have NetGear N300 wireless router (wnr 2000v2)fed by motorola surfboard modem. N300 Port 3 output feeds OOMA internet phone system, Port 4 output feeds HP Touchsmart desktop pc (windows 7). PC will not...
hi,
go straight from your motorola to each wired computer to see if its a wire.can you can login to the router through your wired computer(touchsmart) in the settings and see if all your wired devices are listed, look at the parental controls, reset the whole router to default if you can, if your DSL. try a different jack in the house, get everything off that line but the motorola. go straight from the service jack outside the house(in the grey box) if you have to
jm
Jul 04, 2017 | NetGear N300 Wireless Router
Can't connect tot wireless service because of windows firewall
to connect wireless service to your netgear, we need to connect your laptop directly to the router hardwired. and by ensuring that we are connected try to open a browser and type this inside the address bar. 192.168.1.1. default username is "admin" default password " password " you would be taken to the netgear page. then on the leftside of the screen click on to wireless settings. there you can configure your wireless settings. and click on to apply settings. then try to connect again.
Aug 31, 2011 | NetGear N300 Wireless Router
Bought this netgear rangemax wireless router and don't know where the wires and stuf*** hook up to.the yellow ethernet wire on the back of router where does that go on the back of my computer terminal of...
Take the ethernet cable which is going from your Warner cable modem to your computer, and run it from your cable modem to the input connection of your router. Then take a second ethernet cable and run it from the router (ports 1, 2,3 or 4) to your computer. Log into your router's setup page (see your instruction manual), and set up all the passwords and wireless settings. Please read the instructions for specifics of your particular router.
Jun 26, 2010 | NetGear RangeMax WPN824 Wireless Router
Netgear wireless with mediacom internet-help!
Hi JC
Have a look here
http://kb.netgear.com/app/answers/detail/a_id/12873
This is a walkthrough showing you what to do.
Mar 16, 2010 | NetGear WGR614 Wireless Router
Can't connect my Netgear WGR614v7 to Time Warner Cable Internet
I have just bought a Netgear WGR14 v9 and I was wondering if anyone knows how to set it up with Time Warner. We just swithced from Bellsouth to Time Warner and I don't know how to set it up?
Jan 11, 2009 | NetGear WGR614 Router
I need to set up a home deaktop computer to intranet and share files/folders with wireless (netgear router) with my toshiba laptop and still be able to access internet through time warner road runner...
you can set that up. all you need to do is manually configure your desktop which is connected to that router and have your laptop receive signal from your router...
Apr 20, 2008 | Computers & Internet
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
