Question about Epson Stylus CX4800 All-In-One InkJet Printer
Printer My printer wont print in colour, have changed the ink and cleaned the print head but when i print it comes out blue???
  • 94 Answers
One of the best solution that we can provide you is head cleaning. One of the effective method of Head cleaning is listed below.
1. Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2. Load letter size paper.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) , your printer will require service.
Posted on Jun 11, 2008
Changed black cartridge and now only colour printer will print in is blue/green
The black print head most likely is blocked with dried ink.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 19, 2012 | HP Photosmart 3210 Printer
Canon iP 90 printer problem The blue ink is not printing out - have changed the ink tank but make no difference and the blue colour is printing out a pinkish colour. Genuine Canon ink tanks are being...
It looks like the blue print head is blocked, have a look on ebay, you can get head cleaning kits for just a few £/$.
Here's one :- Item number: 380304689134
Replacement print heads usually work out more expensive than a replacement printer.
Apr 16, 2011 | Office Equipment & Supplies
Lexmark Z615 inkjet printer - whetther I print in colour or black and white, I am getting whole lines of text/image missing. When I use the "clean nozzle" function some of the colours - like...
The problem with your printer is the print head. Usually you have to run the clean nozzle thing 5 or 6 times to clean the print head nozzles and if there's still no improvement after that then print head needs to be changed for the printer to work properly. The bad news is that a print head costs almost as much as a new printer.
Jan 30, 2011 | Lexmark Z615 InkJet Printer
Canon pixma ip90 printer is not printing blue colours. i've tried cleaning but it doesn't work.
If the blue ink cartridge is not empty, then it means that either the pront head or the ink cartridge is clogged. Here are some information about ink cartridge cleaning, and here you can find some information about print head cleaning.
Nov 24, 2010 | Canon PIXMA iP90 Mobile Printer
I have installed a new black and colour ink cartridge but it is only printing in black and blue- why is this?
Your printer head might be blook. For the reason all the colour of ink does not come out through the printer head nozzels. In this condition you should try to come out ink through ink nozzels. procedure
1. print a nozzel cheak. and see what colour does'nt come out.
2. Now open photoshop and take a a4 page and fill it with six colour and print it 5/6 time in a photo paper. If print does not improve call me again. I will give you second tecnique.
Thank you.
Sep 15, 2010 | Epson Stylus C46 InkJet Printer
Model x1270 blue not printing all other colours fine new cartridge heads cleaned but still can not get blue or any colour needing blue
take out some hot water in a bolw, put the cartridge head (where ink comes out) for 5secs just dip it into the hot water, use a tissue tap the cartridge head on it see if ink coming out on the tissue. if not then replace the cartridge
Aug 09, 2009 | Lexmark X1270 All-In-One InkJet Printer
Quality of colour
hi! there, well in connection to your poor printed color there posibility that ink was insufficient to distribute to you photo to print try to visit your ink status, black color is sepated to 3 color catridge.if there's a insufficient ink in catridge,replace or refill any thing as long there is much ink in your catridge,if ok and print still not good,try to clean your printer headdont use any thing to clean your printer herad,the printer will clean your printer head,on maitenance menu,click clean,try several time,also try to align your printer head,click aligned,t check the pattern of your printer,click pattern test.if ok try toprint if the color print is balance,try to print.check the preview before you print adjust the quality color as in yout tate before printing.regards and have a nice day.
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My printer wont print, and i think theres dry ink in the dispenser, but i dont know how to take it out, because the cartridge holder doesnt come out. i have an epson stylus colour 760. btw, i DID change...
Try running the head cleaning cycles from printer utility. then try reprinting. You can press ink button for 3secs as well to auto clean printhead.
Hope this helps
Nov 29, 2008 | Epson Stylus C46 InkJet Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Brother DCP 130C not printing magenta and yellow
after replacing the ink cartridges it took several cleans to come good. I have no idea how to "manually" clean the heads. So I told the printer to do it many (about 7) times. It eventually worked
Aug 11, 2007 | Brother DCP 130C All-In-One InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
126 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
