Question about Cameras
THERE IS A LOCK SIGN ON D CAMERA WHEN I TURN IT ON AND IT'S STOPPING ME FROM TAKING PICTURES HOW DO I GET THE LOCK SIGH OFF SO I CAN TAKE PICTURES.
    Genius:
  • 1,177 Answers
It is hard to help without knowing what camera you have.
Maybe your memory card is locked. SD cards have a tiny switch that can be set to stop the memory being written to. But I don't know if that is the kind of memory card your camera uses.
Posted on Oct 16, 2010
All of the sudden I'm getting blurry pictures? What could be the reasons?
Possible reasons: 1) you are moving the camera when taking pictures, 2) make sure the lens is wiped clean of fingerprints, etc., 3) if taking pictures through glass (i.e. car windshield), make sure the glass is clean and 4) if taking pictures from a vibrating object (i.e. a running car), turn off the car to eliminate the vibration. The curvature of a vehicle's windshield COULD also distort your photos.
Feb 28, 2015 | Panasonic Lumix Dmc-fp2 14 1 Mp Digital...
The card protect appears and i can't take pictures?
Hello there,
Just turn off the camera and take out the memory card. There should be a small tab on the upper left side.. Just adjust that tab to unprotect it then put it back to the camera and start taking pictures.
Hope this helps. Thank you for using FIxYA.
May 30, 2011 | Vivitar ViviCam 8018 Digital Camera
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Panasonic DMC-LS2 camera. Whenever I turn the camera on to take a picture it says turn it off and then on again. I have changed batteries, etc. I can look at the pictures stored in the camera, change...
Is the lens extending at all? There may be some grit stopping the lens extending. Remove all cards, save any photos stored on the camera then enter the menu and perform a reset on the camera. Report back on the above please.
Mar 07, 2011 | Panasonic Cameras
Nikon D60 diigital camera. taking pictures in auto mode and now unable to take pictures. flashing "F- - " with r16 code when pressing shutterbutton.
the lens needs to be set at its smallest f-stop to work properly on your camera. The F error is telling you that the aperure ring is not at the smallest setting(largest "F" number, most likely F22. turn the ring to F22 or whatever is the biggest number and it will work. there might also be a lock on the aperture ring to keep it from moving. Good luck, Worm1855
Dec 20, 2010 | Nikon D60 Digital Camera
Casio Z80 card locked
Make sure the write protect lock is off by taking the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
If the lock is off and you still get the error then the card maybe damaged.
Hope this helps.
Good luck
Jun 22, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Won't take pictures
symptom 1: referred to as FFB (Firts Frame Black). this is when you do not use the camera for a while and when you attempt to take the first snap shot, the Shutter is either stuck, or takes a blank/black picture (some cases the picture came out bluish). Sometimes the camera would freeze and you would need to remove the battery and re-insert it in order to reset the camera. Usually the camera comes back to life and and is usuable for a while until you store it. Sony will fix this free as they identified it as a design flaw in which the remedied (incorrect gear size for the Shutter charge assembly). Contact Sony support as they own all Minolta camera assets and tell them you have the FFB or First Frame Black problem and they will set up a ticket and instructions on where and how to send it.
symptom 2: Camera does not respond at all to the shutter release. Focus is fine, menu works, every function works no problem except for the most important - taking a picture (releasing the shutter). When you first turn on the camera, you hear the Antishift module attempt to center the CCD with a series of clicking noise for 5 or so seconds (not a good sign, also called the death rattle). All 5 AS bars in the view finder are blinking. In this case, the Tebure Assembly (AS Module) has failed and will need replacing. This is not cheap - sending it in to Precision Camera will run you around $250-$280. You can do it yourself if you order the assembly from Sony: Item - ( TEBURE ASSY ), U3008233U, $118.22 ea. via 1-800-488-7669 (will take 3-4 weeks). And follow the service manual to install and calibrate it (via the service manual download at http://www.dyxum.com/dforum/topic36109_post396839.html#396839).
Aug 07, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Usb cable removed whils downloading
Try taking the batteries out of the camera for a few minutes, and see if that helps to "reboot" the camera.
Mar 05, 2007 | Leica Digilux 1 Digital Camera
Flash Not Working/Picture Not Taking Unless Flash Turned Off
well u can´t do much, it needs to have the board to be replaced. normally the repair centre just repair it, and if it is under warranty they will do it for free, probably the store was the one saying that u drop it to get some money.
Feb 22, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
Cameras Logo
19 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
