Question about Hamat 3-2861PC Everest Pull-Out Kitchen Faucet with Lever Handle Polished C...
Leaking at times under faucet on- off handle - Hamat 3-2861PC Everest Pull-Out Kitchen Faucet with Lever Handle Polished C...
New Danze D308340 faucet leaking under handle. Can't remove the capto get to retainer screw, which needs tightening.
is the capp colored red/blue? if yes, take a picky pointy knife (lmao) and peel it off,pick it off,The leak is probable just the adjustment under the handle, the fawcet originaly came with a tiny spud wrench (made like a 2 pick pitch fork, if you cant find one, i use a pair of channel locks pliers, but first wrap rubber glove or cloth around the top of fawcet so you dont scratch it.How old is this fawcet?
Nov 12, 2011 | Plumbing
Water leaking under handle
This faucet has two O rings under the handle..Turn the water off at the valves under the sink, there is an allen wrench screw at the back of the handle. Loosen the allen screw, take the handle off. Then you will have to unscrew the faucet head from the base. (counter clockwise). Once the head is off you should see two O rings you will have to change them both. Also, inspect the O ring on the head itself. You should go ahead and change them all. Hope this works for you.
May 13, 2011 | Kohler K-10416-BN FortĀ½ Single Control...
I have a single handle blanco classic that is leaking around the base I have removed the handle and cartridge but cant figure out how to remove the sprayer to replace the seal
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
Nov 06, 2010 | Blanco Classic Single Handle Faucet with...
Leaky eurostream kitchen faucet
if its leaking under the handle, all you need to do is remove the blue and red cap on the handle under you will find a 1/8 allen screw, loosen screw and remove handle and tighten the brass nut a little which will seat the packing underneath.
Jun 19, 2010 | Plumbing
My faucet is leaking from the pulldown where the hose is conected to the spout ive tried to take it apart is there a special way to take it apart
before you take it apart ,I want you to check,the pullout handle first,because most of the time ,all that is wrong is that little1/2-5/8 in washer between the handle and the hose,It usually runs down the hose ,and might apear to be something else leaking under the sink.If your correct,and it is leaking where you said.Some of the newer faucet have a clip that just pushes together.So you need it fing the clip,and push it in.
Apr 12, 2010 | Price Pfister Ashfield Single Control...
Faucet is leaking from just under the handle when you put water on
"O" ring seal probably need replacement water off disconnect handle and remove valve remove "o" ring and replace
Jan 26, 2010 | American Standard 2021.600.295 Ceramix...
Single handle, about a year old,leaking at the
There will be a set screw on back or under cap on top. Remove handle, next use a phillips screw driver to remove the part that holds on to the cartridge. Then a bonnet that unscrews leaving the cartridge easily repaired or replaced. And there you have it.
Sep 30, 2009 | Plumbing
Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Apr 25, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Hamat 3-2861PC Everest Pull-Out Kitchen Faucet with Lever Handle Polished C... Logo
141 people viewed this question
Top Hamat Plumbing Experts
Colin Stickland
Colin Stickland
ray gallant
Daryl Gleaton
Are you a Hamat Plumbing Expert? Answer questions, earn points and help others
