Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage door sytem was working fine. I lost a remote, so after getting a new one, I programmed it into the door opener. After that, i found the remote I programmed worked, but my wife's remote did not. After programming both of them together, they both worked fine. However, then I discovered the keyless entry (139.53684) wouldn't work.The backlights in the case don't light and seem like it is not getting any power whatsoever even though I have changed batteries on it. Thank you for any help you can give. Ted
  • 4,348 Answers
Ted, it sounds like normal garage door function. Here is my take, you were pushing the button in a fashion that was to clear all remotes. This is done through either pushing wrong button, or pressing the programming button for too long.
Sometimes you need an assistant to be able to activate the wireless key, soon enough after pressing programming button. Get a ladder and a light, climb up and read the directions carefully on your opener. Try to add just the keyless system.
If that does not work,Get an assistant, and do the whole process again, including the keyless.
There are two distinct processes, adding and clearing, and it may be easy to invoke the wrong one.
Your system uses rolling code/invite system. Rolling code relates to a handshake betewen each remote and the base. The code is changed at each use, for each remote. (the keyless /wireless also).
Been there, done this. all for an additional second or two of button press.
Posted on Oct 16, 2010
How do I change the code on my garage door opener. Have one and lost one.
Press an hold the learn button on the garage door opener for 10 seconds. You will notice an amber LED either next to or above the learn button. When the LED goes out the anything that was previously programed will be deleted. Now press and release the learn button once the amber LED will come on steady. Now press the button on the garage door opener you want to program to the garage door opener. You will hear a click and the light bulb on the garage door opener will go off and come back on. Your garage door opener remote is now programed with a new code.
Feb 22, 2015 | Chamberlain Televison & Video
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 41A315-7D garage door opener. I can program one or the other of the two remotes I own. Either one will work fine but I can not get both to work. Its one or the other... not both. The...
You can program more than one remote if they are the same model number and/or the same technology. If your remotes are the same model number then one has converted to an earlier technology. You will need to purchase a new remote and then you will find that the new one will work with one of the old remotes but not the other. Get rid of the bad remote to prevent complications in the future.
Oct 29, 2011 | Sears Craftsman LiftMaster Chamberlain...
Trouble with programing garage remotes and keyless entry pad
Either the keypad is the wrong model for your opener or it has reverted to an earlier technology and needs to be replaced. It is important that you get the model number off your motor unit so you can be sure you get the right keypad for your opener.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
Remotes won't open garage door, keypad will
If you look were the small wires attach to the opener there should be a red program button and instructions on how to program remotes.
Feb 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can't use remote to open garage door
I had the same issue when I moved to a new place.
I was not able to find very much information on the interenet about it. Your remote has lost its sync with the garage door opener.
I called the 1-800 number located on the unit itself (yeah it took a ladder to get it) and the walked me though the setup in about 2 minutes.
I spent longer on hold than it took to setup the remote.
You need to make sure that you a clear on the model #s before you call them.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door close with wireless remote entry but will not open
It sounds like this remote has lost its program! you will have to reprogram it!I hope this helps ya!
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
165 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
