Question about Whirlpool Duet Steam WFW9700V Front Load Washer / Dryer
Cycle stops and F35 displays flashing - Whirlpool Duet Steam WFW9700V Front Load Washer / Dryer
I blew mine out with compressed air and it worked, You have to take the cover off and remove the small rubber hose. Then blow out the hose and blow into the small hole on the sensor. It is easy to remove from the machine, 3 screws in the back then remove the rubber hose, twist the unit so the bottom is facing the back of the washer and it pops right out, then remove the wire plug.
Posted on Apr 07, 2012
  • jayadams4
    jayadams4 Apr 07, 2012
  • jayadams4
    jayadams4 May 04, 2014
    But it only worked for a few days, ended up replacing it!
4 Suggested Answers
  • 530 Answers
SOURCE: F35 flashing
if it is less than one year old call for service it should be covered. if not take the kick panel off and locate the tech sheet it is either in the kick panel or in the cabinet to the right. it will give you a list of error codes find out what it means and let me know thanks
Posted on Jun 25, 2009
  • 1416 Answers
SOURCE: Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Posted on Jun 03, 2010
rickead1
  • 1998 Answers
SOURCE: In some cycles the word
one of our techs has already answered this on the f35 error code click here http://www.fixya.com/support/t400054-error_code if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future Thanks Rick
p.s to repair this issue you would replace the analog pressure switch the switch's part number is W10156252
Posted on Mar 22, 2011
May tag 5000. f35 what does that mean
"F35" means Analog Pressure Sensor Failure
If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Hope this helps.
Jul 09, 2011 | Maytag Washing Machines
In some cycles the word sud appears on the display. Then the cycle will stop and F35 appears on the display.
Mar 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code F35
hello
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Code F35 on Kenmore Elite HE5t front loader washer.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
F35 message, will not run through cycle. Starts to and then the F35 starts flashing and eventually shuts off.
Check between door boot seal and drain hose in basket. If this is clogged with lint or sock, towel it will code f35 or sud
Oct 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore Elite HE5t washer flashes SUD continually, then goes to F35 mode and shuts off. Help!
Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
Aug 02, 2009 | Kenmore Washing Machines
Error code F35
May 18, 2009 | Kenmore HE2 Plus Front Load Washer
Sears Kenmore HE3 Error Code F35
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet Steam WFW9700V Front Load Washer / Dryer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
