Question about Toshiba Satellite M45-S331 Notebook
Cannot install XP or Win2K - non-compliant ACPI - any ideas? Loaded new BIOS v.2.0, Start XP install, gets to where it says at the bottom of the screen "Setup is starting Windows" and freezes.
  • paulgm Jun 09, 2008
    3 year old Toshiba M45 S331 laptop, PATA, was XP, having BSD problems. Reformated the HD, ACPI BSD, removed drive and attached to PC, re-formatted and checked out OK. Re-installed - same-O same-O. I've been in the business 20+ years - never saw this before.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    well..hate to suggest may need to reformat your drive, and begin anew
  • 458 Answers
IBG42008 He stated that he was installing a new O.S. in his question.
What are the specifications of your Hardware?
You did not tell me what the system was at all. It might not be able to handle the O.S. that you are loading. Are you sure that the Hard drive is not bad.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Do the following to check your Hard Drive.
This sounds like a bad hard drive. What make of hard drive is in it?
Figure out what brand hard drive it is first. Then go to the website of the manufacturer.
While you are on the site look for software for hard drive repair. It could be listed in many ways. Download the windows version if you have another computer to test this in. If you do not have another computer to test this in you will have to use the Dos version. The instructions will come with the siftware.
Then you will go through these steps.
Do you have another computer that you can use to check the hard drive? If you have another computer or access to another computer you can download a hard drive utility that can diagnose and possible repair the hard drive. Is it a SATA hard drive? If it is a SATA hard drive you can plug it directly into another computer that has a SATA cable. If it is not SATA you will need to buy a converter so that you can hook it up to the other computer. This will be an external slim hard drive enclosure. A desktop hard drive can be put in another desktop and used as a slave drive. Just make sure that you look at the back of the Hard Drive and make put the jumper on the slave pins. Then you can run the test through the other computer to test the Hard Drive. The test will let you know if the Hard Drive is bad or not. If you can see your files on the drive you might want to back them up before you start the test. If it comes back as good go to the next step.
Posted on Jun 04, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you try what I told you to do? I will still help you, but you need to tell me what you have done.
    Did you think about checking the memory? The memory slot or the memory could be going bad. I have had a similar problem just recently and the memory was bad.
    How did you test the hard drive? Toshiba does not provide a hard drive test for their drives. I also just recently had a Toshiba do the same thing. I ran every test that I could run and it checked out okay. I did got it to boot into Windows XP. Then I ran test on it with it running. After a few days of this, it restarted and finally came up with the Smart Drive Failure. Your only choice might be to try another hard drive and see if the same thing happens. These Toshiba laptops seem to be having a lot of problems. This is the third one in a matter of day's that has had hard drive problems. I do not know if it is a PATA problem or just Toshiba drives. These PATA drives have only been out for a couple of years. I guess if we techs keep seeing problems we will have to let the companies know that there is a problem. It could be the heat issue in the laptops. Most people do not understand that a laptop can't be placed on a flat surface like a bed. You see this all of the time on T.V. shows.
The bios in this system is not fully acpi compliant
Guess your computer is not compatible with Windows 7. Reinstall windows XP run compatibility test from Microsoft
May 16, 2014 | Dell Inspiron 15 (N5050)
How to turn off acpi mode during the installaition
When you first start the XP install, you are in 'text' mode - you know, blue and white screen, no graphics.
When you get to the point where it says at the bottom "Press F6 to install additional storage drivers", just hit F7. Change your system type from ACPI compliant to Standard Computer in the menu that comes up.
Is this message received on an existing installation OR are you now trying to install XP - that "during text mode set up" refers to the install.
If it is already installed Press F8 and select Safe Mode.
If you get in XP there go Start, right click My Computer, click properties, click the hardware tab, click device manager and on the My Computer expand the + sign.
If it says ACPI there, then it already is ACPI compliant.
This actually stands for "Advanced Configuration and Power Interface"
The issue is more than likely a driver, memory or possibly a flat CMOS battery.
hope this helps
Sep 17, 2012 | IBM Netvista M42 8307-81U Pc - XP Pro - P4...
Blue screen of death says acpi bios noncompliance. Help!!
Did you change something in the bios? Enter the BIOS and check the Power Management or just Power settings and disable ACPI. This should solve the problem.Windows would again find new hardware and then should work normally.If ACPI not found under power it could also be under Advanced tab. Did you install any new hardware?.The hardware might be non ACPI compliant hence the error.
Jan 21, 2011 | HP Compaq Presario SR1303wm PC Desktop
Dear Friends, My Toshiba Satellite M45-S2652 (PSM40U) is showing problem during windows XP/Vista/7/Even Windows ME installation. This system BIOS is not compliant with ACPI. Bios ver was 1.5 which upgraded...
Please go through the following Article if you are trying to install XP in the Compute. This should help you resolve the problem.;en-us;Q314830
Dec 06, 2010 | Toshiba Satellite M45X-S331 Notebook
ACPI Compliant
Don't worry check out on the net about this motherboard, put that serial number of the mother board on the site and download the BIOS drivers. update that BIOS by DOS prompt , problem will be solved
Jun 15, 2009 | Computers & Internet
Dell Inspiron 1100 Bios and ACPI
Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Manually install the Standard PC hardware abstraction layer (HAL):
1. Reboot the computer to restart Setup.
2. When Setup starts again, press F7 when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL. You should also contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant
Mar 16, 2009 | Dell Inspiron 1100 Notebook
How to install Windows Vista On IBM NetVista 830331G
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Feb 10, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Acpi complaint - reg
I have located some info on this board. it was released as a "Medion" board
there is some BIOS and driver stuff available HERE and select customer care.. you need the exat model no or the serial no of the PC to continue though.
Also may me of assistance as I think they are the real manufacturer but as I cannot read German I cant really be sure. they have the link to Medion on their webpage...
HIH and please post back results
Jun 23, 2008 | Intel Motherboard
Fiend your solution direct from intel. Here is your solution........
Jan 17, 2008 | Intel Motherboard
Toshiba Satellite M45-S331 Notebook Logo
118 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
