Question about Panasonic PT-51HX41 51" Rear Projection Television
Picture distored, wonky colours and bowed at the bottom [PIC Inside]
To help better I am going to attach a photo. This TV was manufactured in 2002 and has NEVER given us any issues. Just this morning upon powering up the TV viewed as it does now. Distorted picture, pictured bowed at the bottom and colours really messed up.
The video source is DVD, i grabbed the first one i could (LOL).
Anyways, just looking for a yes/no it can be fixed and possibly a cost.
Thanks in advance! :)
  • 2 more comments
  • skyhawk04 Jun 09, 2008
    Same issue here. Never had an issue with the TV and today my picture looks just like yours. I saw the response posted to your problem. Did you try this yet? Did it work? What is an IC and where did you buy yours?
  • Anonymous Feb 18, 2009
    Had the same problem today
  • Anonymous Mar 03, 2009
    Turned mine on this morning and had the same problem as described here.
  • blunte2000 Mar 20, 2009
    I too have the same problem. However, I've been able to isolate the problem by covering the green projector (there's also a blue and red projector) with a piece of cardboard to get the picture back to a somewhat normalcy. I figure there's a connection between each projector and the independent circuit board each have. Will gather more information as I experiment more with transistors and switches.
  • Panasonic Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiPicture distored, wonky colours and bowed at the b - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture distored, wonky colours and bowed at the b - 578ba6c.jpgef="http://www.fixya.com/support/t1631691-red_aura_in_middle_55_phillips#" >Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 26, 2009
  • 4,234 Answers
Relatively easy to fix. If you can solder, you can probably fix it yourself. Look for a couple of large black ICs attached to a heatsink. They should be marked STKxxx. These are the convergence ICs. Try resoldering the pins first. If that fails, replace the ICs. They will be about $20 each or so.
Keep us posted.
Dan
Posted on Jun 03, 2008
Black screen, green light on the bottom is on, electric plug is on house plug, no picture, was working fine last night, now only black screen!
Do a hard reset to this set, and then check. If it do not help you, check and replace its main digital board. It will be faulty.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 08, 2017 | Televison & Video
I have a lg tv 60 inch tv ln5600 when powering on red stand by light blinks 3 time then no light pic or sound not backlight and no image when using flashlight treid replacing power board does same
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jan 08, 2017 | LG Televison & Video
WHY DID MY VIORE SCREEN RESIZE TO SMALLER SCREEN
Screen size depends on the broadcast signals aspect ratio, the TV adjusts for that automatically, the picture can have no bands or be banded top and bottom or on both sides.
Jan 07, 2017 | Viore Televison & Video
I have sound but no picture on my tv
This is a popular question. Most of the time you either need to make sure all connections are not loose or just need to turn off your tv and receiver and unplug. Wait for 1 minute then reboot.
I recommend this short video as it walks you through some diagnostics for other possible problems.
Repair TV With Sound But No Picture
Nov 24, 2015 | Luxor Televison & Video
Its a lg brand colour tv 53cms. Model no-21SA1RG3T8/2009- What is his E.H.T Number
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/. It has schematics to many popullar brend TVs. Hopes it will help you find out the number of the EHT transformer.
Jan 20, 2015 | Televison & Video
How to attach vcr to a tv using cable
attaching a VCR to a TV using cable is done with an RF modulator costing about 30 bucks from Walmartyou take the cable out from the VCR into the RF modulator. this device has RCA outputs separate video and audio that will go to your TV
Jul 14, 2014 | Televison & Video
Colour tv 20CA3RB-A9
Sir I want sug for TV fault plane raster not work any panel button or remote pls tell me
Jul 15, 2013 | LG Televison & Video
My tv has gone some orange colour
Try unplugging your tv and anything connected to it - you might want to take a picture first so you have a reference. I would also unplug everything connected to the tv: cable, stereo, etc. Wait a few minutes, then plug in and re-connect everything.
You can also go into your TV's setup menu and adjust the picture settings - try restoring the default settings first.
Mar 22, 2013 | Televison & Video
TV just flashes different colors
You have entered a diagnostic colour test. With the TV powered on, hold the 'Menu' & 'Enter' together, then press the power button. Problem resolved
Jun 25, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
Panasonic PT-51HX41 51" Rear Projection Television Logo
249 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
