Question about Whirlpool Washing Machines
How do I remove the fabric softener cap from my Whirlpool top loader? It does not seem to screw off and I can't seem to pull it off either (like most machines I've used) Don't know the model....about 15 years old and it's a Clean Touch if that helps.
    President:
  • 1,430 Answers
Most of those had a plastic ring just below the dispensor that you slide up then the dispensor pulls off. Try this link
Washer agitator video
Posted on Oct 16, 2010
Fabric softeneer despenser has water in it. We have not used the despenser. Have a whirlpool cabrio top loader
Had one where the softener dispenser had all kinds of dried up crud from the softener which caused the water to collect there instead of drain down. It actually looked like wax, after cleaning it out the water problem went away.
Apr 20, 2011 | Whirlpool GSC9455 Top Load Washer
Can't seperate agitator from base...stuck !!!!!!!!!!!!!!!!!!!
Remove top cap and remove the screw holding it to the shaft of the gearcase. Some models have a fabric softener dispenser you can pull or twist off, then a cap, then possibly another cap with a seal that pulls off before gaining access to the screw. You will need extensions for a socket set.
Sep 18, 2010 | Washing Machines
Is the fabric softener dispenser at the top of the agitator replaceable?
Yes it is,although the whole peice running half way down will probably have to be purchased..It's called the(Clothes Mover)it has finns running down & can be removed by a bolt down the centre after removing the top cap.
May 21, 2010 | Whirlpool LSR5132PQ Top Load Washer
Water colects in lid sometime during the cycle.Drains onto washed clothes when lifting the lid to remove clothes. Water seems to be combined with fabric softener. Bleach holder also is filled with water....
I had the exact same problem. The problem is that your fabric softener dispenser is clogged up with a lot of dried, sticky fabric softener. The flooding comes from the part of the cycle when water that is to be flushed through the fabric softener dispenser can't drain properly so it spills into the bleach dispenser and onto the top and into the lid gasket as well.
To remove the dispenser for cleaning, you need to open the top of the washer. (First pull it away from the wall.) Carefully pry off the little emblem in the front center of the washer lid. Then remove the screw. Then slide the top forward to you about a 1/2 inch and prop it up carefully.
You then need to remove both hoses that are attached to the bleach and fabric softener dispenser (part of the same unit). Then unsnap the combined unit from the washer top. Then clean all the gunk out by running it under scalding hot water in the laundry tub and swirling the gunk out. Don't attampt to remove the blue round fabric dispenser part from the unit.
Put it all back together and you're good until you clog it up again with too much fabric softener; maybe several years again.
Good luck.
JRR
Mar 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
2 piece aggitator with fabric softener dispencer, top part is loose and spinning separate from bottom. How do you remove the top portion tosee if it can be fixed
Pull off the softener cup
Remove the cap underneath
Remove the bolt
Pull up on the agitator to remove....if it is stuck, drizzle some liquid wrench into the bolt area
Nov 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I can't get top part off the agitator
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
If you have a 2 part agitator assembly (Fabric softener dispenser, top agitator and main agitator)
First, push down on the ring around the bottom of the fabric softener dispenser and lift it off the agitator.
Pry the top cap (a short screwdriver into the slots in the cap works) of the top agitator.
Looking into the center of the top agitator, you'll see a plastic piece with a 1/2" square hole. Using a 1/2" socket set extension, unscrew the piece carefully. You might have to hold the bottom agitator in place while you do this.
The top agitator pulls up.
You'll see a bolt and screw holding the bottom agitator on. Carefully unbolt this one and the entire bottom agitator will pull up.
Sep 27, 2009 | Washing Machines
How to pull apart fabric softener dispenser
MOST DON COME APPART SOME HAVE A BLUE RING PUT IT UP AND PULL THE SOFTERNER UP AND PUT IN THE WASHER RUN A LOUD SMALL AND HOT WATER AND LET IT CLEAN IT SELF IN THE WAHSER
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Remove and replace fabric softener dispenser on kenmore model 20952992
I just did it. All you do is pull up on the blue part -- put the fingers of both hands under the rim and pull. It isn't screwed or bolted on. If there's a lot of gunk built up, it's all the harder to pull up. Be prepared for some yucky stuff. It would be nice if that whole section would come out, since you have to clean the area below with Q-tips.
Jul 21, 2008 | Washing Machines
Whirlpool Frontloader - the bit where you put the fabric softener in fills up with water and dosent drain. When I put fabric softerner in there it just stays there. Have pulled out the tray and cleaned it...
you can remove the top cover of the washer( 3 screws alongside the top rear of unit) and top will slide back and off, the dispensor is right there with sort of a tear drop shaped cam and lever.Make sure thats in tact. start the washer , and youll see it cycle foward and back if broken youll need to replace the part, dont think the line is blocked (if it was youd get fabric softener overflowing out front), im thinkin the water never gets to that area of dispensor. id start with the lever system
Mar 09, 2008 | Washing Machines
Washing Machines Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
