Question about Goodman GMS807034ANA Heater
The unit seems to cycle fine the ignitor glows for 5 sec goes out then it recycles after about a minute
    Problem Solver:
  • 8 Answers
SOUNDS LIKE THERE IS NO GAS GETTING TO THE IGNITER, GAS VALVE COULD BE BAD
Posted on Oct 17, 2010
I have a frigidaire gas stove model #FGF337AWJ.
I went through that once and believe it or not it was the ignitor. Instead of a thermocouple these new ovens use the amount of current going through the ignitor to prove the flame. Seems like after it gets ot a certain temperature the amps drop off enough to cut out the flame and then it will try to recycle. If it is not that it would be the thermostat but they very seldom go bad. I would reolace the ignitor first I think it will solve your problem.
Nov 14, 2009 | Frigidaire FGF337BC Gas Kitchen Range
Mdg 4000aww turns on and heats when started. runs for 5 five minutes then flame goes out. ignitor glows but no flame. one minute later dryer still running ignitor glows, no flame. this repaets until turned...
Either the venting needs cleaned or the coils on the gas valve are bad. Unhook the venting from the back of the unit and run. If works ok then clean venting. If you still have the problem, replace the two coils on top of the gas valve.
Sep 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Ignitor won't ignite after working for 2-5 min
Your fuel supply is OK?
If the igniter comes on and you have fuel, there is no problem ... for some reason you dont have fuel, seems to me.
Did you check the gas valve(s). There nay be several.
If you have gas and the valves are on ... you have an electric (gas relay valve) problem.
Sep 27, 2009 | Dryers
GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 24, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer -...
Stops heatinng
Hi, first thing to check is the venting. If the vent is plugged, it will cause the heat to short cycle.
If later in the cycle, the ignitor glows but will not ignite the gas, you will need to change the coils on top the gas valve. This is a common problem.
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Burner comes on for 30 secs or so and shuts off. Ignitor cycles
it sounds like the gas valve solenoids are shorting out. there are two coils that operate in tandem to allow gas flow. these coils can eventually overheat and cause the gas not to flow as well have a rattling sound from the plunger inside the coil trying to move inside the weakened coil. the coils can be replaced and will come in a pair with guide pins to help you put them in correctly. one coil will have three wires going to it and the other coil will have two wires going to it. pretty simple fix and should solve the problem
hope this helps....jay
Mar 06, 2009 | Whirlpool LEQ9858P Electric Dryer
Igniter only glows on permanent press cycle and not timed cycles
I unplugged the ignitor and put the leads from my multi meter into the plug to monitor the signal to the ingnitor. I got 120 volts only when I turned the timer switch counter clockwise or to the permanent press cycle. When I turned the switch clockwise or to the timed cycle I wouldn't get the voltage to the ignitor. While in the timed cycle, I turned the switch counter clockwise and as I started counter clockwise pressure on the switch knob I got 120 volts to the ignitor. There is a little play in the switch and when taking up the play in the counter clockwise direction the switch would engize the ignitor. The timer switch is bad.
Feb 05, 2009 | Hotpoint NVL333GY Gas Dryer
Main burners don't come on, though the ignitor goes bright
you should hear a click ,its the valve opening ? of check to see if the air fiter is clean ,
Jan 02, 2009 | Goodman GMS90703BXA Heater
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
