Question about Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo 1800 fails to print fully
This printer produces great photos but is commonly failing to print part way through a job. Epson cannot solve the problem but it is obvious that it is well known to them. Can you help please.
  • Lowerhouse Jun 03, 2008
    From Lowerhouse
    The printer begins printing then stalls part way thrpough the job. Sometimes almost at the end but it can fail at any point.
    Epson tells you to change the settings by setting up a new folder called Espool which did nothing, then to run msconfig and disable all programs that run at startup then to reintroduce them one by one and try to print - until one makes the printer fail again!
  • Lowerhouse Jun 10, 2008
    Hi Bestdarngood.
    The prints start OK then stop leaving the familiar trail of diminishing ink and a partial print. I have used Epson 'support', they have advised disabling the progs. that run at startup,usung a shorter USB cable, downloading the latest Driver for the R 1800, creating a new folder called Espool. I have used the USB sockets on the front of the computer in preference to the rear ones- no luck. This is now an old problem that Sys.Restore won't help. Regards Lowerhouse.
  • 3,037 Answers
What did Epson all try with you so I don't try to repeat something that they did? Please let me know and then I'll give you suggestions to what may work.
Posted on Jun 03, 2008
  • 3 more comments
  • Benjamin Patri
    Benjamin Patri Jun 03, 2008
    By failing to print, does it print a page and then won't print the rest of the document or what? Can you explain this a little more as it would help figure out a solution better
  • Benjamin Patri
    If this just started happening, may I suggest trying a system restore to a point before this problem came up. You can do this in the Control Panel under Performance and Maintenance
    it is completely reversible so give it a try and if you have any questions about it let me know, thanks
  • Benjamin Patri
    The system restore will only work if this problem is new and if you have had this printer working well before, if this isn't the case, please let me know
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • Benjamin Patri
    Benjamin Patri Jun 10, 2008
    This is what you should do, contact Epson again, the corporate office preferably and keep asking for someone higher up and then demand that they replace the printer as no troubleshooting options would fix this problem. The only thing I think can really be done is get a new printer as something is messed up with programming or communication in this printer which can't be fixed on your own. Let me know how the call works out and if it doesn't I'll try and figure something else out but this isn't an easy fix. One other thing I would try is to see if you install on a different computer whether it will do the same thing. Also, how much is the printer messing up?
    Sergeant:
    Champion:
  • 230 Answers
This may be due to the change in the paper allignment
  • 1 more comment
  • balachander megavarnam
    balachander megavarnam Jun 03, 2008
    put the paper correctly and make sure that the paper is not crushed or
    not having and wrinkles because if the paper is not good also this
    problem may occur
    dont click print for more than once, if it takes time wait for sometimes because clicking many times may also leads this problem
    thanks for using fixya
    you may press accept button on my solution if you are satisfied
My printer keeps saying this document failed to print before it prints or half way through the job
When I go to print a document it feeds paper through without printing anything ... my x63 keeps saying clear system error then press clear. ...www.fixyourownprinter.com/forums/inkjet/13953
Dec 06, 2009 | Epson Stylus R265 InkJet Photo Printer
Epson photo stylus 320 will not print anything text or pictures printer will print the head check routine ok. printer will go through the process like it is printing but nothing comes out. we recently...
Check for a new or updated driver at Epson's web site. Remove the old driver & install the new one. If that fails, you may be better off communicating by e-mail or telephone directly with Epson to get back on track. Good luck.
Aug 29, 2009 | Epson Stylus Photo R320 InkJet Printer
My printer Epson Stylus PHOTO R230 does not print
The printer does not print only dragging a paper without printing.
3 option to solve
make sure your
1. heads are working
2. flex cable connecting the heads
3. main board
Most common that i found is to replaced the main board. or replace parts of other main board if you have some extra. hope it can help.
Jun 29, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printer cacelling job half way through
Try buying a new usb printer cable, just a thought - could have a dodgy connection.... Also - try a different pusb port on your computer.
Steve
www.yourhandinmine.co.uk
Apr 23, 2009 | Epson Stylus 1400 InkJet Photo Printer
Ink was low I put a new cartridge in still says low wont print.
Hi
try reinstalling the ink. if all fails call epson for replacement ink at 562 276 1300
Jan 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Problem printing - Epson stylus photo 895
1 bring out the catridge of the printer to clean and make sure the ink flow during the cleaning.
2 insert and reset the catridge.
Oct 11, 2017 | Epson Stylus Photo 890 InkJet Printer
Failure of an Epson Stylus R 1800 printer to print properly conistently.
Here is the solution:
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Jun 16, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
