Question about Garden
My OASE SP310G fountain pump will not pump the water more that 2 inches up the hose. Is there anything I can do or is ti time for a new pump
2 Suggested Answers
pondking
  • 21 Answers
SOURCE: OASE fountain pump fluctuates height every other day.
No there is not 2 speeds. That model is asychronous so power fluctuations can affect pumping. How clean is the plug end and how dry is the receptacle? Is there is chance a extension cord is used [code violation almost everywhere] in this hookup? Perhaps it's just debris circulation and restricting intake?
Posted on Jun 24, 2009
Bosch washing machine leaks
what size is the line you are using for the gray water. what i mean is if you are trying ti use the same size hose as the original discharge
hose, the pressure to high. the hose original was about 1 inch diameter, the hose use to go up than the hose hook shape goes into the drain pipe thats 2-3 inches diameter for draining the water went into the sewer system, if your trying to use 1-1/2 hose, the diameter not enough air or room for all that water. i dont think the lenth the issue its the diameter and amount of pressure that being forced down small hose or pvc pipe.
Oct 06, 2015 | Bosch Washing Machines
Oase sp310g
Yes.Get the new impeller,take the unit apart,remove the impeller and put the new one on.Just do it.You never know tilya find out.Only way to find out is to just DO IT.
Apr 15, 2014 | Garden
How high does this pump example high high can fountain top be if pump is at bottom?
From the photo on the box, it looks like it will through a nice stream 4 to 6' high.
No details available though. Make sure the outlet of the pump is right at the water surface. You will need some rocks, bricks or a hidden floating platform to make it the right level.
If it is below water level, the fountain will be much smaller (may lose half of height for every inch below surface. 1" = 3 feet stream, 2" = 18 inch stream, ...
May 06, 2011 | Pontec Submersible Fountain Pump Sp 70g
Pump runs and is fine on the output until i connect back to filter and there is not enough flow
Your filter may be clogged if not check for clogs in the fittings running between them. You will have some loss of pressure pressurizing the filter unit but it should not be a drastic loss.
Mar 30, 2011 | Oase Aquamax SF Pumps 3500 for Ponds ()
Fountain pump motor runs but no pressure to push water
You can try to force prime with a garden hose. Put the hose in ether side suction or discharge.
Jul 07, 2010 | Little Giant Submersible Fountain Pump
MY OASE PUMP SEEMS TO BE LOW ON POWER, IT PUMPS WATER BUT NOT ENOUGH TO GET TO THE FILTRATION TANK
Check to be sure that the impeller is not clogged in the center of the fins.
Sep 09, 2009 | Garden
Jun 21, 2009 | Little Giant Submersible Fountain Pump
Aerate a pond
I live near Memphis TN so don't have that pesky "frozen water" problem. However, I do aerate my 2,500 gal goldfish pond with a Oase Biosys Skimmer (free standing/ floating skimmer) which is powered by a Laguna fountain pump. I attached a small pipe on the discharge end of the pump & set the pump so that this pipe is a few inches below the water's surface. The discharge provides a small fountain effect that keeps the surface moving while aerating the water. The skimmer keeps the leaves / debris off the top of the water the pump keeps the water moving...and moving water will not freeze. Hope this helps
Raincreek
Dec 24, 2008 | Aquascape Designs Aquascape - AquaForce...
Garden Logo
611 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
