Question about Vacuums
My Hoover UH70015 keeps shutting off. I know it has a turn off if it gets overheated. Howver, I looked at the belt and it looks stretched (maybe because it got overheated?). How to I replace the belt myself? I can get the bottom plate off and the brush roller off, but can't tell how to unhook the other end of the belt.
  • 8 more comments
  • Judy Allison Oct 16, 2010
    So I shouod replace the brush roller instead?
    Sp should I replace the brush roller then?
    There isn't anything to speak of there, but I cleaned them off. The problem seems to be that the brush roller turns quite freely but there's space between the belt and the track it goes in, so you can spin the roller without the belt moving, either direction. Thats' why I thought the belt might be stretched.
  • Judy Allison Oct 17, 2010
    How do I get to the motor drive shaft after I take the bottom plate off? It is totally covered. I see nothing that would be a release to gain access it to it.
    How do get the belt off of the motor drive shaft? After I took off the bottom plate to remove the brush roller I see no way to gain access to where the end of the belt is that hooks around it.
    I have gone through my owner's manual. I have looked at various manuals and videos online for my model and others. However, the instructions in my manual only says remove the brush roller and belt with no instructions on how to remove the end of the belt that is around the motor shaft.
    And the video instructions are not using my model in the demonstrations. I can tell because my model (I believe is the UH 70015) does not show the indicator for the motor getting too hot and it shows a red latch to reveal the end of the belt that goes around the motor drive shaft and my vacuum does not have such a latch. I really believe the belt is stretched, but I can't get to the end on the motor shaft. Any suggestions? If you cannot see the thread I've been on with other experts, please let me know. they have not been able to answer this.
  • Judy Allison Oct 18, 2010
    I'm afraid that we aren't at "There you go" just yet. If you'll notice this page says nothing or shows nothing about how to remove the belt from the motor drive shaft. I got everything on this page figured out by myself, but nobody is helping me understand how to get the old belt off and the new belt on the motor drive shaft.
  • Judy Allison Oct 20, 2010
    I need to know how to disconnect the belt from the motor drive shaft. The owner's manual tells me remove it but not HOW. Can somebody help me, please????
  • Judy Allison Oct 22, 2010
    So there's nothing else that needs to come off the bottom, right? I have to hook the belt around the motor drive shaft using the screwdriver?
  • Judy Allison Oct 23, 2010
    Well, even before I was talking with anyoneI was doing everything you said up to the slide the brush roller into the new belt because I can't get the old belt off to replace it. It slides on fairly close to the motor and the shaft is about 3 inches long. Even using a screwdriver there is no way to remove the belt without taking something else off. When I try to use screwdriver, it won't move toward the motor (and I don't think it would come off that way anyway) and the shaft is too long and covered so that I can't even push the belt to the end of the shaft. What else can I do????? I've been at this a week and my house is getting dirtier by the minute. :)
    President:
  • 1,515 Answers
Hi, if you are able to get the bottom plate off and remove the brush assembly, the belt should come right off as at the brush end it slides around in to the groove and the motor shaft end fits on exactly the same way. When you grasp the brush, just lift off the belt and look for the other end that just slips over the motor shaft and set brush back in place. You can also leave the brush in place, raise the belt end just enough to slide the belt off the brush roller and it will slide right off of the motor belt shaft. The belt is small so you should have no problem spotting the motor shaft. If the vac is shutting off on overload this may be due to dirt and objects in and around the hoses or string and other things wrapped around the brush. I would give it a good cleaning with a stiff nylon type brush, check any filter it may have and make sure there is nothing that may be blocking the air way. This will or should take care of the motor drawing excess amps. Get back to me if you have any more questions or need my help. Please rate my thread for me, thank you.
Sincerely,
Shastalaker7
Calif. State Contractor
Posted on Oct 20, 2010
    President:
  • 2,047 Answers
Changing a belt on a vacuum cleaner is fairly easy. Following just a few easy steps will produce the desired results. The procedure uses very few tools and supplies. It is a good idea to change the belt on a vacuum cleaner every six months, depending on usage. This will prevent the belt from breaking during use, which can cause damage to the vacuum cleaner.
- Check with the owner's manual to determine the correct size belt for your particular vacuum cleaner. There are no universal, one-size-fits-all belts, so be sure you have the correct size.
- Place newspapers on the floor. Unplug the vacuum cleaner and tip it upside down on the newspaper. Look for the screws that attach the bottom plate to the body of the vacuum cleaner.
- See what type of screws the vacuum cleaner has, Phillips head or flat head. Using the proper screw driver, turn the screw to the left to loosen and remove it. Remove the bottom plate. Wipe the area down with the rag to remove all dirt and dust.
- Locate the belt, which will be attached to the beater brush on one side or in the middle. Slide out the beater brush and remove the belt. Remove any tangled strings and debris from the beater brush.
- Slide the new belt onto the beater brush. Slide the other end onto the motor. Place a screw driver inside the belt by the motor to relieve tension on the bar where the belt attaches. Holding the screw driver in one hand, gently stretch the belt and slide the beater brush into place. When the beater brush is in place, remove the screwdriver.
- Wipe off the base plate, line it up with the screw holes and replace the screws. Plug in the vacuum and make sure it operates correctly.
Hope this solution has been helpful?
Posted on Oct 18, 2010
  • 2,299 Answers
I would say that the belt is not the problem. It is more than likely the bearings in the roller brush. The roller gets hard to turn and causes the motor to overheat.
Posted on Oct 16, 2010
  • 1 more comment
  • Rodney Clark
    Rodney Clark Oct 16, 2010
    No. Just clean the ends of the roller where the bearings are. Hair and strains of carpet get caught up in the bearings and make it very hard to turn. You can also use some oil and oil the bearings.
  • Rodney Clark
    Rodney Clark Oct 20, 2010
    You will have to lay the belt flat to get it out.
  • Rodney Clark
    The shaft will have a small space at the top or bottom. Whichever way you look at it. You will have to lay the belt on its side to fit it through the small space at the end of the shaft.
    Master:
  • 497 Answers
OK I found it!! Just click on the folowing link and go to Page 16 of the User Manual. It willexplain how to accomplish what your task entails.. ok?
http://www.hoover.com/pdfs/manuals/UH70015.pdf
And there you go... Hope I was able to help you out.. PLEASE DON'T FORGET TO RATE MY SOLUTION, OK? THANK YOU!! :)
  • 857 Answers
Replacing a drive belt
1.Unplug the machine and flip it over so you can access the agitator brush.
2.Unscrew the bottom plate that holds the brush in place, using a screwdriver.
3.Lift out the brush by pulling the roller ends out of the slots in the vacuum base. If the drive belt isn't completely broken, one end will be wrapped around the agitator brush, the other around the motor drive shaft. Slide the belt off of each part. Take it to a hardware store to get a replacement.
4.Inspect the agitator brush before installing the new belt. Sometimes thread or hair will wrap around the ends or elsewhere on the brush roller. This can prevent the agitator from turning and cause a belt to fail prematurely. Cut any thread or hair with a sharp knife and pull it off.
5.Install the new belt. Slide one end over the agitator brush and the other over the drive shaft. Then reinstall the agitator brush. You may have to pull on the agitator brush to stretch the new belt a bit so the roller ends fit into the vacuum base.
6.Reinstall the bottom plate.
Clearing an obstruction
1.Inspect the hose, wand and cleaning tools to locate the obstruction. Debris often collects where one part plugs into another, or where the hose connects to the main vacuum housing. Remove the parts one at a time and remove any debris you find.
2.Clear any hidden obstructions by pushing a broom handle through the hose and wands.
3.Reassemble all the parts.
Posted on Oct 17, 2010
  • Jayant Jha Oct 17, 2010
    Refer your user manuel for details.
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
Hoover Platinum Cyclonic Bagless Upright Vacuum, UH70015 squealing sound
have you checked the belt for the brushbar it may av stretched and needs replaceing here is the manual on link below
http://hoover.com/file/556/
Feb 16, 2013 | Hoover U5780-900 Windtunnel Cyclonic...
The brush does not move when turned on. The model number is UH70015. The belt appears loose.
There are two belts on this machine. The belt on the brush roller will appear loose when in upright locked position. Releasing the handle to an in use position releases a spring loaded idler pulley which increases tension on the brush roll driving belt. Check whether pwr on/off button flashes when attempting to turn on. This may indicate an obstruction or faulty sensor.
Feb 22, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
The belt on my hoover cordless is not spinning when I turn it on
You need to replace the belt. Even though the belt may look fine it can be stretched and therefore it won' t turn the roller brush against the resistance of the carpet. You can get Hoover replacement belts here:
Hoover Replacement Belts
Oct 29, 2009 | Hoover Vacuums
Belt won't stay on
A belt will slip off because it is stretched, or the brush bearings are worn, or the motor drive shaft is misaligned.
Hoover belts fit snug.
After as little as week they begin to stretch. Even though they are not broken, they will spin loose. IF you can stop the brush with little effort and the belt keeps moving the belt is stretched. Do not buy a belt buy size, buy it by model. But 2 and store your spare under the hood of the vac if possible.For best cleaning results,change every 3-4 months if you vacuum weekly. 6 months at most.
Most times your old belt will be stretched as much as 30% oversize. If it looks shiny inside it has likely been slipping.
Before reinstalling check that your brush rolls freely and clean the bearings at the end of the brush roll.. Once reinstalled check it again before turning on the vac.
Sep 13, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Belt Keeps Coming Off
Replace the belt with afresh, proper sized one. Yours is stretched. It will be shiny on the underside. hoover belts are meant to fit snug. Check the bearings on the end of the brush roll to remove dirt and thread. The proper belt will need to be stretched into place using the brush for leverage. Likely that your low carpet is more dense causing enough drag to throw the stretched belt.
Sep 13, 2009 | Hoover U6616-900 WindTunnel Bagless...
Hoover Wind Tunnel 2 Making Noise While Operating
sounds like your brush roller bearings are going bador cloged up with carpet strands if you can take the bottom open and remove the brush roller look at the ends and see if you see any melted plastic or see if the ends feel loose like wobble back and forth.once you take the roller out turn the vacuum on and see if you hear the same noise.also check the belt and see if it looks burnt on the inside of the belt. and does it look stretched out .the belt might be stretched out and fluttering when running.feel free to cal me and maybe i can help you further with it.i'm not one of the techs .i'm just trying to help people.i don't charge for my advise
Apr 05, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
The brush rollers on my hoover mach 5 won't turn. I've cleaned everything and checked the belts and everything checks out fine. I had the vacuum for about a year.
I had the same problem. The problem is the small v-belt for the roller brush (Hoover part# 38528034). Although it looks in good shape, it's been stretched too large for the idler to keep good tension. The tension on that belt varies with the handle geometry so if you slam handle all the way down the belt gets stretched a little bit each time.
Oct 06, 2008 | Hoover Vacuums
Brush won't turn
The belt may look ok, but if it is more then a few months old, then it has stretched to where it won't turn under load, just slips. If it is very tight feeling, then check down where the pulleys are, the V belt has a black roll that maybe jammed and not pushing against the V belt when the handle is in the down position.
Sep 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
132 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
