Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Xerox c2424 system error 07.010.043
    President:
  • 2,072 Answers
That is fault caused by the print head not being able to move freely.
There are a few things that can cause that. Here are the most likely problems.
1. With the side covers removed, there is a stainless steel block located about midway back toward the bottom of the frame. If is silver and about 1 inch square. What happens with that is some ink spills into that print block and the print head will not move back and forth properly. You remove the spring holder over that block and most likely need some channel lock pliers to slide the block off if it has ink in it. Clean that and the shaft thoroughly
2. The wiper blade is stuck between the print head and the drum. Normally happens with a power failure or not properly shutting the machine down properly. You have to remove the document feeder, scanner, side covers and ink loader ( where you put the ink sticks).That will expose the drum/print head area. See if the blade is stuck and gently peel it from the print head, then run the remove light stripes procedure in troubleshooting from the user interface.
3. The Process control motor can come out of timeing. But 90 percent of the time it is a contaminated print block or stuck blade.
Posted on Jun 05, 2008
System error # 07,010.43:27456 on a xerox c2424 copier
The printhead is stuck in the tilt position, need to replace the process motor camshaft kit, part number WCC2424-Z2
http://www.iteminconline.com/wcc2424-z2_wcc2424-z2-xerox-workcentre-c2424-process-motor-camshaft-kit.htm
Jul 07, 2015 | Xerox Office Equipment & Supplies
Xerox c2424 error codes
Drum disconnect. The drum heater is not drawing the expected
power from the supply.
AC power supplied by power sources such as uninterruptible power supplies (UPS's) or DC-to-AC inverter systems, may not supply enough current to properly power up the printer. In these cases, the printer may report printhead jet-stack or reservoir
heater disconnect, drum heater, or preheater errors (37,002.47 thru 37,012.48).If you do not hav a UPS connected then probably it is the drum heater problem
Aug 05, 2014 | Xerox C2424 Copier
Xerox c2424 37,002,47:280890
The 37,002 error code is for a defective heater in the printhead 650-4354-00. There is no reset or workaround for this error.
Unfortunately, the part is fairly expensive, but the C2424 is such a workhorse, you may want to repair it.
Whit Item, Inc.
Dec 06, 2010 | Xerox C2424 Copier
I am receiving error code 39,012.40:76243 on C2424
Replace document feeder. 004k07270 $390.00
Sep 04, 2009 | Xerox C2424 Copier
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
System error
7,0XX.6x Errors - Program Faults
a.
Reset NVRAM and retest.
Jul 02, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox C2424 error code 19,003.48 and 07,010.43
for error code 07,010.43
Access the power switch by opening the Interface Cover on the right side of the machine.
click on this:
for maintainance
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_maintenance.pdf
for troubleshooting:
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_trouble.pdf
Jan 30, 2008 | Office Equipment & Supplies
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
172 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
