Question about Refrigerators
I have amana TL20 fridgerator it is freezing in bottom
  • 132 Answers
Either turn down your controls or check your thermastat/defroster unit.
Posted on Oct 16, 2010
Fridgerator not cold and freezer not freezing
You will need to clean the condensor coil. It is usually under the refrigerator on newer models and in the rear on older models. All you need to do is use a vacuum to clean it. Also try to leave some room behind the refrigerator, do not keep it too close to the wall. It needs to circulate the warm air it extracts.
Jul 15, 2012 | Roper Refrigerators
Amana BB20VE - Food Freezing in Crisper
Have you checked it's not in fast freeze mode, and that the setting on the thermostat is about in the middle?
Apr 18, 2012 | Amana Refrigerators
Upper unit freezes up even tho both top and bottom are turned down. only does it occasionally
Its the defrost problem. The drain hole is clogged and water freezes in the unit instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/amana-abb1927de-bottom-freezer-upper.html --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Amana ABB1927DE Bottom Freezer...
Amana fridge (mod #sxd22s2) is freezing foods on bottom level- dial turned to lowest setting & temp. is 28 to 32 degs.at bottom of fridge.
seeing that 32 is freezing point of water,its not suprising that food is freezing.it should be 38f or +3c.when was the last time you did a FULL defrost(NO HAIRDRYERS PLEASE).ALSO CHECK DOOR SEALS ARE TIGHT ALL ROUND.
Nov 27, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Where is defrost timer on amana arrccb
The ice in the ice tray freeze together as if they melted for a time then refreeze. It appears to maybe be a defrost problem. Can I adjust the defrost cycle on My Amana Bottom Freezer Refrig?
Nov 01, 2010 | Amana ARB224RCC Bottom Freezer...
The cold water dispencer freezes in my amana bottom freezer refrigerator
The water line runs through the door and this is where it freezes. It's usually defetive insulation. Other than replace the door you may can tape or other wise fasten more insulation to the inside of the door in the area you think it's freezing in.
Aug 26, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Frost on back wall of freezer, side by side, wont freeze
It's most likely a defrost issue. One or more of your defrost components have failed. Defrost components are defrost thermostat, defrost heater, and defrost timer or board depending on model
Nov 21, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking water inside fridgerator
You need to manually defrost then let sit over night .Pour warm water down the drain hole if does not go down fast than you will need to clean drain tube out with wire start at the rear of the unit and there will be a drain tube going in the drip pan good luck :)
Sep 10, 2008 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
