Question about Pride Mobility Products Jazzy Select 14
My jazzy select 14 on the controler near the joystick lights up what looks like a yellow wrench in a 9 flash. Lights 9 times stops then lights nine more times over and over . please help
  • 132 Answers
Well a wrench means the obvious that something needs adjusting , if it came with an instruction manual search for the code 9 blinks will mean.
Posted on Oct 16, 2010
My Jazzy Select HD stopped working. It turns on, but wont move. I have chasing lights going from left to right. I tried unlocking, that did not work. Any other ideas?
make sure that the free wheel levers are in drive position. Also the charger is unplugged. restart and see if that took care of it. Also check the wires coming out of the joystick that they have not been damaged somehow.
Oct 10, 2016 | Pride Jazzy Select Hd JSELECTHD
Yellow wrench lights
I would think there is a communication error from the joystick to the controller. One time i had this and one of the plug ends was broken off from the joystick cable. Make sure all the plug tips are straight and not missing or broken on the joystick cable and also on the joystick and controller. it could be a simple fix like replacing the cable, but if you have a broken part in the controller or the joystick ports you will have to replace the defective part.
Aug 16, 2014 | Pride Jazzy Select 6 Indoor Power...
Lock key keeps blinkinglights blink 9 times
Depending on the controller type being used you either have a controller solenoid brake fault (sticker on bottom of joystick will say "PG Drives" and have 9-bars flashing) or a communication error between the controller and joystick (Dynamic Controller flashing wrench).
Repair for PG Drive is to replace joystick/controller.
Repair for Dynamic is to clean, remove and reseat or replace joystick cable.
Nov 12, 2013 | Pride Jazzy Select 6 Indoor Power...
What does a flashing yellow light mean on the joystick? the light looks like the shape of a wrench.
Hi Judy,
According to Pride's troubleshooting documents the service indicator (wrench icon) will flash when a fault is detected by the dynamic controller.
The number of flashes, followed by a 2 second pause, indicates the issue. You will need to count the flashes to determine the cause and a possible solution.
I have typed the flash codes below, but you can also see them on a larger table here: http://www.fixya.com/support/p3641679-pride_jazzy_614_hd_jazzy_614hd/usermanual-6B42026-pdf
FLASH CODES
Code #1
  • Flash Code: One, pause, one
  • Cause: Possible Stall Timeout
  • Possible Solution: Turn joystick off, then on.
Code #2
  • Flash Code: Two, pause, two
  • Cause: Battery Fault
  • Possible Solution: Charge batteries, check battery connections and fuses.
Code #3
  • Flash Code:Three, pause, three
  • Cause: Left Motor Fault
  • Possible Solution: Make sure the left motor is plugged in.
Code #4
  • Flash Code: Four, pause, four
  • Cause: Right Motor Fault
  • Possible Solution: Make sure the right motor is plugged in.
Code #5
  • Flash Code: Five, pause, five
  • Cause: Left Park Brake Fault
  • Possible Solution: Make sure the left brake is not in freewheel mode.
Code #6
  • Flash Code: Six, pause, six
  • Cause: Right Park Brake Fault
  • Possible Solution: Make sure the right brake is not in freewheel mode.
Code #7
  • Flash Code: Seven, pause, seven
  • Cause: Joystick Fault
  • Possible Solution: Check the joystick connection.
Code #8
  • Flash Code: Eight, pause, eight
  • Cause: Power Module Fault
  • Possible Solution: Check connections to the power module and batteries.
Code #9
  • Flash Code: Nine, pause, nine 9
  • Cause: Controller Communication Fault
  • Possible Solution: Check bus connections from the joystick to the power module.
Code #10
  • Flash Code: Ten, pause, ten
  • Cause: Controller Fault
  • Possible Solution: Contact Technical Service for assistance.
Code #11
  • Flash Code: Eleven, pause, eleven
  • Cause: Incompatible Device Fault
Sep 05, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
How do i fix the chair when the control flashes 9 times
Typically when a joystick flashes 9 times, it indicates there is a problem with the solenoid brake(s). I recommend contacting Pride Mobility for a Certified Technician in your area to look at this chair.
Jun 19, 2013 | Pride Jazzy Select 6 Indoor Power...
Light flashes 9 times
This is a cable disconnect code. Follow the cable going from your joystick controller to where it connects to another wire under or behind your seat. Disconnect and reconnect. You also will want to look at the cable closely for any pinches or cuts. This will also cause the 9 flash code.
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
I JUST PURCHASED A JAZZY WHEEL CHAIR AND IT IS I THINK 2003 MODEL WHEN TURNED ON THERE ARE 3 RED LIGHTS AND 4 YELLOW LIGHTS FLASHING AND NOTHING HAPPENS
the 7 lights indicate a joystick problem which means the joystick/controller will have to be replaced since there is no self repair fix Unless you can locate a good used joystick/controller for cheap (around $600.00 rebuilt) I would return the chair and get my money back Hope this helps
Jun 20, 2011 | Pride Jazzy 1103 Ultra Standard Power...
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
My Jazzy select wheelchair does not run
you move the joystick and can hear something quicking in the motors
May 17, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Pride Mobility Products Jazzy Select 14 Logo
631 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
