Question about Bunn CWT 15-APS Coffee Maker
I obtained Bunn CWTF15-APS from a restaurant next door to my office. They were no longer using it and had left it outside over the winter. When I hooked it up there was water leaking as a result of a few frozen sections of tubing - which I replaced and that all works without leaking now. When I pluged it in nothing seemed to be happening so I pushed the Start button and it filled with water which heated up quickly, the hot water tap pours hot water, yet the brewer did not begin to flow. I pushed start again and if began filling again - until it overflowed... I turned it off and disconnected the power. Is there a procedure for first time use that I am missing? How should I set it up to run for the first time - and when should it begin to pour hot water through the sprayer and into the coffee pot?
  • Mark Footer Oct 17, 2010
    Thanks for the help Jonnie - I used a wire and vinegar to clean out any lime buildup in the sprayer.
    On further inspection it appears that the lid to the tank is not sealed. Is this type of coffee brewer supposed to have a sealed tank which uses pressure from the heated water to push the hot water through the sprayer assembly? If so it it a lost cause of the lid is warped?
Have you tried running vinigar or a cleaner throught with the water or running a wire up it .Sometimes they plug up withlime and will not allow the water to run.Be sure and rinse it well after the cleanser so everything runs clear and you may have to do this two or three times, depending on how pluged it is.
Posted on Oct 16, 2010
How to adjust water level on bunn
use a measuring cup or bucket that goes up to 64 ounces in order to accurately callibrate. also, delime the sprayhead with a flathead screwdriver or paperclip first to ensure proper flow
Feb 13, 2014 | Bunn CWTF15-TC
My bunn cwtf15 won't put out hot water from tap, and won't brew hot enough water even after adjusting thermostat?
your thermal fuse has blown. it's in what is now brown tubing and is located in the top right rear of the machine. remove the top lid, remove the trough drain nut and trough to get to it. you can either bypass it with a jumper, or call (800) 352-BUNN (2866)
Jan 06, 2014 | Bunn CWTF15-TC
Bunn coffee maker cwtf15 water is boiling over
if it's actually boiling, replace the high temp limit fuse on the top of the tank on the inside rear of the brewer. may be stuck shut. if it's just overflowing the container, recallibrate by using a 64 ounce measuring cup and the instruction on the inside of the front panel
Oct 02, 2013 | Bunn CWTF 15-APS Coffee Maker
I have a used Bunn CWTF15-APS, that warms the water but does not heat all the way up. I'm wondering what is causing this problem. thanks so much
I would remove the front panel and check the pressure stat to make sure it is set high, turn knob all the way to the right the back it up 1/4 of a turn. It that is done and after 7 minutes water is not hotter then the problem is on the top, the hi-limit needs to be replaced.
Aug 19, 2011 | Bunn CWTF 15-APS Coffee Maker
I have cwtf15-aps older model. Device is wired and plummbed in. lights are working but i get no hot water. Has not been used for about 3 years.
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Dec 12, 2010 | Bunn CWTF15-TC
I have a Bunn CWTF15. Water does not fill the coffee pot full anymore. Is there a float that needs to be adjusted? Would descaling help this problem? Thank you.
If u haven't cleaned it out using 3/4 vinegar to 1/4 water, some times this will happen. after running this thru ur coffee maker, (u won't believe the junk that comes out), then run full pots of water to rinse out (2x's). This should help it perform better.
Sep 12, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
Bunn model CWTF15 brews coffee but coffee not hot enough
Check the setting on the thermostat behind the front panel, it might not be set correctly, turn it all the way high the back 1/4 turn.
Nov 05, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
Can you turn a CWTF15-APS Airpot Coffee Brewer to a pour thru
Yes, most Bunn CW models have the ablilty to be used as a pour over. There should be a lid on top.
www.kaldi.com
Jul 20, 2009 | Coffee Makers & Espresso Machines
Bunn cwtf15, water does not heat, ready light on all the time
There is an inline thermal fuse on the right side of the element, check to see, if it has resistance, if not replace.
Mar 31, 2009 | Bunn CWT 15-APS Coffee Maker
Bunn CWTF15 Airpot brewer
If the unit does this constantly, it's probably seeping past the solenoid valve. you can try taking it off and check for dirt or corrosion that is stopping it from closing properly, or replace it. the solenoid valve is located under the front panel, and is silver in colour with 2 wires & 2 copper tubes coming to it. as always, please be sure there is no power coming to the unit before servicing!!
Oct 25, 2008 | Bunn NHB Coffee Maker
Bunn CWT 15-APS Coffee Maker Logo
148 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
