Question about Black & Decker Hedge Hog 20-Inch 2.8-AMP Dual Action Hedge Trimmer #HS1010
I accidently cut the extension cord with my trimmer. Is the trimmer now useless or is there a reset button?
Fuse probably went in the plug/extension-replace plug and mend the cable or replaceit
Posted on Dec 03, 2010
I accidently cut the electrical cord while using the black and Decker hedge trimmer TR116, now its not starting.
Did it cut it all the way through.? Have you repaired it? Has it been repaired adequately? Check it hasn't blown the fuse in the plug when it was cut, protecting the circuit.
May 14, 2016 | Garden
I have cut the extension cord when using a ryobi RHT-600R hedge trimmer. It now won't work when using a new cord. Is there something I need to reset?
Was it plugged in to an outside receptacle? If so are you trying to plug into it after new cord? Try a different receptacles if you want to be sure go inside the house and plug it in. Try it. If it works. The outside recepticles are on a GFCI circuit an have a test and reset button on it reset it if it does not work check the panel box for a trip breaker turn it all the way off then on again to reset breaker.
Nov 29, 2014 | Garden
Electric motor stopped after cutting power cord
did you hook the wires back up correctly ???... did you pop the circuit breaker ???... then yes, you did. no probably not yet but that would take some internal checking. after checking, no parts are available... throw it away my friend
Oct 05, 2013 | Homelite Garden
I have an 18" Craftsman Bushwacker hedge trimmer
The wire into the handle may have been pulled and come loose. You will have to take the handle apart to check. They are simple.
Sep 28, 2017 | Craftsman Garden
Cut cord with mower by accident. connected new cord but no dice. is there a reset button?
Did you check the outlet, you might have tripped the breaker,
or you fried the outlet.
Plug the mower into a outlet that you tested with a lamp or something
so your sure there is power at the outlet, and at the end of the extension cord, if there is power to both but not the mower, contact the company because there is no reset button.
What ever outlet you use to plug this thing into, you should have a ground fault outlet installed, for two reasons, safety for you, and protect the mower.
Feb 05, 2010 | Black & Decker 19" Electric Lawnhog...
I cut through the cord by accident, can I buy a replacement wire?
If you are handy, you can do this. Most trimmers some with a very short cord to which you are expected to attach a extension cord. What exactly did you cut? If the short cord that may have come with it ... disassemble the body of the machine and reconnect a shorter (the one you cut) cord. If it was the extension, that is easy. New ends available ar your hardware store.
If there is a trick part,it is in reassembly. Pay attention to how it was configured when you took it apart.
hope this helps
Jun 30, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Cut orange extension cord
yes it can. you have to slice and solder the wires together and wrap tightly with vinyl electrical tape. if your not familiar with soldering you can have it repaired at your local repair center.
Sep 29, 2008 | Garden
Black & Decker Hedge Hog 20-Inch 2.8-AMP Dual Action Hedge Trimmer #HS1010 Logo
1,356 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
