Question about Vizio Televison & Video
I turn the hd vizio off, then I turn the power off to my residence to replace a electrical wall socket, which was in a different room of the residence. Upon replacing the the wall socket, I turned the power back on from the circuit box. I then turn the HD vizio on, the set now will not turn on. Any advice will be helpful?
  • Vizio Master
  • 8,457 Answers
Tries unplug,replug the tv back an hour later.The tv now,will reset itself back to the factory setting.The tv should work now,not than the power supply board got shorted some how.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Oct 16, 2010
How to repair a wall socket that has stopped working.
turn of breaker --remove wall plate screw ---remove socket disconnect wires ---reconnect --replace --cover and turn on breaker
How to Replace Standard Electrical Outlet For Dummies How To Replace An Old Electrical Outlet Wall Plug Replacement
Oct 10, 2016 | Electrical Supplies
No sound from E371VA Vizio TV
tried first with unplugging and re plugging the tv unit to reset the power supply as will as the any program.
Nov 14, 2012 | Vizio E371va 37-inch Full Hd 1080p 120 Hz...
I just had a power surge and now my vizio blueray player wont power up. Is it fried?
It is a possibility. Try testing it connected to a different outlet in another room. Make sure other devices work with the socket you are testing with. If it still will not power on, something is burned out.
If it does power on, something may be wrong with the initial wall socket, thought I doubt it.
Apr 27, 2011 | Vizio Televison & Video
My printer will not turn on
First, try pressing and quickly releasing the Power button to start a Power On/Off cycle. Do not hold down the button. If this resolves the problem your done; if not continue on.
Inspect the power cord for visible damage; if damaged will need to contact HP to replace.
Disconnect the power supply (power module and cord) from the power source (wall socket) and the printer.
Test the power source, wall socket with or without your power bar or surge protector in place, with a small appliance you know works to confirm you have power. You may want to test the wall socket first and then test the power bar, etc. to make sure each component is not the problem.
If the appliance works then need to investigate the power supply. If the small appliance does not work you may need to check your electrical panel for a tripped breaker and possibly consult an electrician to check your electrical wiring.
To test the power supply plug in to the working power source; if the green light on the power supply does not light up you will need to contact HP to replace the power supply.
If the green light on the power supply lights up; reconnect to the printer.
Press and quickly release the Power button to turn the printer on. if the printer does not turn on you will need to check the USB cable.
Disconnect the USB cable from the printer.
Press the Power button to turn on the printer; if the printer turns on you will need to replace the USB cable.
If printer does not turn on, check the battery if your printer has one. A red light means the battery requires recharging; if it is still red after recharging, replace the battery.
If none of these steps resolve your issue before replacing the power supply try plugging the power supply directly in to a different working wall socket with no power bar or surge suppressor.; Press the power button.
If still no power to the printer you need to replace the power supply.
I
Dec 22, 2010 | HP Photosmart 8050 InkJet Printer
Red lin appeared on my vizio tv and now its not
is this dead set? if no power at all check first ac cord for the ac line from wall socket going to tv power ckt. or else we need to open back cover.
Mar 31, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Flashing red power light
Try the following steps:
1. Disconnect the modem's power adapter.
2. Reinsert the power adapter directly into the wall socket.
3.Remove any power strips or surge protectors temporarily to ensure that these items are not preventing the modem proper operation. Note: Make sure that you are using the power adapter that came with your modem.
4. Plug the power adapter into a different wall socket in another room.
5. Press the reset and hold the reset button for 1 minute. Then turn it off for 1 minute, and then turn it back on.
6. If the power light is still red, then you will need to get a replacement.
Dec 28, 2009 | Westell Wirespeed LiteLine 6100...
Vizio TV will not turn on
Sounds like your power board is bad. contact vizio support and let them know. some vizio parts have lifetime warranties with free service call. see if it is covered, and hope it is. if not, i would start with the power board, you should have an led, light, on the power board that should be on, if it is not, the power board is not on. you can see this light without opening the TV, just turn off lights in the room and view from the back of the tv. hope this helps.
Apr 08, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Televison & Video Logo
109 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
