Question about Compaq Presario CQ60-220US PC Laptop
WEN MY COMPAQ CQ60 STARTS UP IT SAYS PXE-E61:MEDIA TEST FAILURE, CHECK CABLE.. THEN IT SAYS PXE-MOF:EXISTING PXE ROM THEN SAYS INSERT BOOT DISK AND PRESS ANYKEY I DNT HAVE A CLUE WOT THIS MEANS CAN ANY1 HELP THANK YOU
  • kyledurkin Oct 16, 2010
    no ive had it given to me so if i buy a new hard drive would it work and thank you
    President:
  • 2,653 Answers
Usually it means your hard drive has crashed.
The PXE is your computer trying to connect to a network server (virtual hard drive).
Did you have any important files on the computer?
Posted on Oct 16, 2010
  • 2 more comments
    no the computer was given to me because it is broke so if i buy a new harddrive wud it work and thank you for the help.
  • RescueTechLA
    RescueTechLA Oct 16, 2010
    More than likely, it probably uses a SATA drive but to make sure unscrew the two screws holding the hard drive panel on the bottom of the laptop. You should see a symbol that resembles a circle on the panel somewhere. Open it up and carefully remove the hard drive from the computer, most laptops have either 1 or 2 screws holding the drive in place, once removed you either have to slide the drive out or pull the drive upwards, carefully examine the drive and use common sense you'll see which choice is right, just use slight force.
    Take the old drive to Best Buy or anywhere else and get a drive that works. Right now they've got a 250gb drive for 47 bucks and a few better ones for just slightly more.
    Any SATA 2.5 drive will work. I prefer Western Digital or Seagate. If you want some extra speed get a 7,200 rpm drive, otherwise a 5,400 rpm is fine.
    Once you've got it installed you'll need to install your operating system via cd / dvd.
    Hope this info helps. Sounds like you came up!
    sorry to bother you again but how do i install my operating system
  • RescueTechLA
    RescueTechLA Oct 17, 2010
    Boot from the operating disc (XP, Vista, Win 7) and just follow the prompts. Win 7 is the easiest to install in my opinion.
Disk boot problems
Insert your OS disc to repair the damaged boot sector and then replace the hdd as that could be the cause.
Sep 11, 2014 | Computers & Internet
R780 pxe-e61 media test failure
It is not recognizing the hard drive, Open it up reseat it. Then check BIOS by pressing F key noted on startup. It must be noted there in order for it to boot correctly.
Jan 19, 2013 | Samsung R780 Red Intel I5-460m...
PXE-E61 Media test fail, PXE-MOF Exiting Broadcom PXE ROM
Disable PXE in the Boot Sequence in the BIOS setup [F2]
Aug 10, 2012 | Dell Computers & Internet
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
PXE-E61 : Media test failure , check cable PXE-MOF: Exiting PXE ROM. No bootable device -- insert boot disk and press any key don't have a boot disk
It sounds like your hard disk has gone, or not being recognized by the computer... Check if it seats well in it's place.
Unfortunately, laptop HDDs don't last long these days.
Oct 18, 2010 | Acer eMachines 520-2890 Notebook
My Toshiba says PXE-E61:Media Test Failure, check cable PXE-MOF: Exiting PXE ROM. No bootable device--insert boot disk and press any key. How do I fix it?
check the boot sequence in bios
make sure that the first boot device is your HDD and disable the network boot
Sep 03, 2010 | Computers & Internet
I have a Satellite 450D-13X laptop. Tonight i switched on and this message keeps rolling what can i do This Product is covered by one or more of the following patents: US5,307,459,US5, 434,872, US5,...
Go into the BIOS and disable the Option: Network Boot ROM. This message will show, because the system is trying to boot from your Ethernet ROM.
Jul 11, 2010 | Computers & Internet
How do i repair my pc it gives a message that says Intel UNDI, PXE-2.0 (build 082) Copy Right (1997,1998,1999)Intel Corporation VIA Rhine II Fast Ethernet Adapter V2.43 (2005/12/15) PXE - E61: Media test...
Dear,
If you are using PC then make sure that Boot from PXE Rom is disable and boot from hard disk drive is enabled. Check your BIOS setting for configure it.
Regards,
Rakesh Kumar
Network Support Engineer
Apr 07, 2009 | Compaq Computers & Internet
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Compaq Presario CQ60-220US PC Laptop Logo
243 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
