Question about Pentax Optio E60 Digital Camera
I dropped my camera about 4 ft high, and the lens was crooked at first. I got it back to normal but now when i turn it on it says lens error 0x01110000. how do i fix this?? I have a SANYO vpc s1070
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Aug 24, 2012
2 Suggested Answers
Jimsta01
  • 405 Answers
SOURCE: Lens error :0x01110000 That's what it says when
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Posted on Jun 12, 2010
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Camera dropped, lens won't retract or expand
You can buy a new A590 for under $110 these days, so the professional repair option may be out. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 24, 2009 | Canon PowerShot A590 IS Digital Camera
MY DIGITAL CAMERA IS A VPC-S770 AND IS READING ERROR 1114 ON THE LENS
This is what the Sanyo Customer Service team responded with for me, and it worked:
Take a look at the lens to see if it is crooked or mis-aligned. If it is, with the camera turned off, try to straighten the lens to see if it will click back into place. If it does, turn the camera on and off a couple of times to see if the lens will open and close as normal and then try using the camera as normal.
If the lens is not crooked or straightening does not solve the problem, the camera will need to be serviced.
The warranty coverage period is 90 days for parts and labor.
For non-warranty service, check your yellow pages for camera repair to have a local service technician take a look at the camera for you.
Please consider that the normal out of warranty labor cost can be around $ 75.00, this does not include the cost of parts and return freight upon completion of repairs.
Oct 05, 2008 | Sanyo VPC-E760 Digital Camera
Sony dsc w55 when turned on zoom lens seems to be crooked &message tun power off &on again nothing happens
Hello
If the lens barrel is crooked it is normally a sign that the camera has been dropped or knocked.
If you are careful you may be able to straighten the barrel up by trying to push is back into place.
If you are unable to do this you will have to take it to a service centre and have the lens block replaced.
Oct 03, 2008 | Cameras
I dropped my camera and the lens is crooked now and when i turn my camera on it sayslens error:126,1,0,-9
Usually a "lens error" is only going to be fixed by sending it into repairs or an authorized service center. I would contact the repairs department of your cameras manuacturer and they can tell you where to send it.
Sep 12, 2008 | Cameras
Canon powershot A560
you need to get camera serviced-usually lens jumps off track or is crooked and gets jamed-did camera get dropped?if older model than 1 yr usually 100-125 to repair-if new model still in warranty they will tell you someone broke it and it's not covered-as a last resort if you are going to toss camera anyway put pressure on lens as you try to zoom in and out or put lens between teeth and try to force back in place
Aug 12, 2008 | Canon PowerShot A560 Digital Camera
Jammed lens
Hey latyrant,
If the lens visibly looks crooked then the lens is probably broken and needs to be repaired by an authorized service technician. One thing you could try is placing the camera on a flat surface with the lens pointed up and holding the shutter button in, while doing this turn the camera on. Sometimes this will force the camera to try and focus before the camera can register the lens problem and sometimes it will force the lens back into alignment. If this doesn't work you could bring it to a Geek Squad® precinct in a Best Buy™ store and they could send it out to get looked at by a technician. I will say that the cost of digital camera repairs often exceed the value of the product. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 24, 2008 | Cameras
Sony Cybershot Camera DSC-S650 won't stay on.
that happen to my camera, exactly same thing. and i figured out when i dropped it the zoom out zoom in lens was bent and stuck part way in camera. My brother was playing around and moved lens and it started to work again. If lens looks a little crooked try moving it or putting it straight. Hope it helps
Nov 08, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Lens Stuck
Same problem guys!!! LENS HAD GOT STUCK - ABOUT ONE THIRD OUT after a knock. After lots of playing, and tapping and batteries in and out tried the whole twisting and pulling thing whilst turning off and on.
After a few minutes it came free and whole lens popped out. I then had to twist the outer part of the lens to straighten that up and allow it to fully retract. Works a treat now!
PS Tried the Sony online chat support - useless!!!!
Sep 08, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Dropped camera and don't know if it is fixable
Generally speaking, there is nothing you can do to correct the problem other than to send the camera to the appropriate factory service center for correction of the error. Following the repair cost you should decide, whether it worth it.
Aug 03, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Pentax Optio E60 Digital Camera Logo
63 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
